Posts: 1,580 |
Can somebody explain the SOS/Lufa thing?
** Mike **
"You might beat me in a straight line, but I'll embarass you in the turns"
Posts: 1,609 |
Ya, You use a lufa or some SOS pads to block the carbon buildup. Lufas are cheap and work pretty damn good. Thats what I am using.
1998.5 SVT contour #5979 3L
1995 Mercury Mystique 2.5L auto, all ghetto fo sho
Posts: 710 |
Originally posted by RandyCSVT: are those plastic PVC tubes? I have heard bad things about putting that stuff in your engine bay.
Seems that most of the people on this site (at least that have taken pictures) have used PVC without any issues, though it's technically *supposed* to release chlorine gas. My separator is made of ABS.
morbid
2000 Contour SVT (black)
Posts: 1,506 |
I'm REALLY interested in one of these also. I had my intakes yanked and cleaned by hand last summer and I am now looking to keep them from getting so gunked up again.
Here's a compound question about the way you have these made: Can you ONLY open/remove the plug off one end and drain it; OR can you ALSO remove/replace the scrubber stuffed in it?
MSDS, SHO-shop Y, custom 2.5" catback; xcal2; 63mm TB, K&N 3530; Koni struts, Aussie bar; THaines forks, Quaife, SpecII, UR fly; DMD; Nima UD pullies; Stazi brakes; f&r Pole120 mounts. Just a daily commuter car. Silver '98 SVT E0 #3159
Posts: 1,609 |
You can take the cap off one side AND clean/ replace the scrubber or w.e you want inside of it. In a nut shell its fully serviceable
Posts: 751 |
Originally posted by starjammir: Ya, You use a lufa or some SOS pads to block the carbon buildup. Lufas are cheap and work pretty damn good. Thats what I am using.
Loofah.
Whirling dervish of FFOG.
Posts: 1,609 |
Sorry I'm not up on the spelling for the girly things
Posts: 487 |
Originally posted by teamSVTour: so what exactly does this do again? Is it the same as an oil acusump (or whatever its called)
SOLD Polarg M-28 super bright white bulbs. Replace yellow stock license plate bulbs. See add in classifieds.
WANTED:: EVO style CF hood
Posts: 6,106 |
Originally posted by teamSVTour: Originally posted by teamSVTour: so what exactly does this do again? Is it the same as an oil acusump (or whatever its called)
No, it's not the same at all. What these do, is catch the oil that would otherwise enter into your intake tract, causing your intake manifolds and throttle body to get gunked up with carbon.
Mark
2000 Black CSVT
Posts: 32 |
I'd be interested as well. You'd be suprised how much crap gets stuck in your intake where you'd like steady flowing air...
