Page 2 of 3 1 2 3
#1569366 05/12/06 12:00 AM
Im running a Lightning IAT. Youll have to solder it in the old the wiring, but it works.
#1569367 05/12/06 07:00 AM
Originally posted by TC'd Swazo:
Originally posted by MapOfTaziFoShoâ�??¢:
Should look like this i suppose.
Sweet, is it up and running??
That looks like a vortec to me? Even has the fuel pressure regulator. Stazi also has the aluminum UIM, no? Does look like his bay, but sans turbo.
#4559 of 6535 born on Feb 17, 1998 Black 1998.5 CSVT FOR SALE [cleaning house]: SVT rear swaybar. Reasonable offer and its yours!
#1569368 05/12/06 12:13 PM
Stazi Offline OP
That's offroad SVT not me. As if I'd go back to an inferior supercharger.
#1569369 05/13/06 06:22 AM
W
W
Originally posted by Stazi:
Originally posted by WorldTour:
Why do you want a lightning IAT? IAT are basically a dummy Ford Sensor and don't differ a great deal from vehicle to vehicle.
It's got to be the screw in type. Our IAT isn't made to seal into a pressurized area.
EDIT: I ordered the screw-in IAT from Part's America. It's going to cut it damn close!
I just used a die to thread my stock IAT(after I filed off the plastic ridge that held it into the stock intake), cut a piece of rubber for a gasket, then drilled and tapped a corresponding hole in the intercooler after the exchanger right before the TB for mounting. Screwed in tight and has held very solid with no leaks.
Took about 30 minutes, cost = $0.00
Spending no money and little effort to make a better part/product/mod.........Priceless.
#1569370 05/15/06 10:59 AM
Good idea, War... Nice one!
FYI the ADC kit has the IAT in the pipe that goes into the turbo- I suppose it would serve the engine better to have it after the IC...
Dan G. and his Cougar Forged internal (Diamond & Pauter) full 3L, "Monster" Kinger F/I cut & P&P, T3/4 60 trim .82A/R ADC turbo, SPEC Stage 3, Torsen, Greddy Profec-B SPEC II, Apex'i Timer, Lots of Gauges! Used to have: 3.0L SVT hybrid
#1569371 05/15/06 11:27 AM
Thats how mine is routed. Just tapped the Lightning IAT after the intercooler.
#1569372 05/15/06 01:19 PM
That's where my IAT is, between the TB and IC.
2005 Ford F150 SuperCab FX4 1964 Chevrolet Impala SS 1998 CSVT: 354HP/328TQ @ 10 psi, now gone
#1569373 05/15/06 01:48 PM
Stazi Offline OP
Got the IAT and it connects directly into the stock connector.
I'm tapping and threading the intake manifold and putting it in there, just like the lightning setup.
PS - motor is in, shopuld have it all done by tonight - tomorrow the latest.
#1569374 05/15/06 02:50 PM
W
Back In Black
Back In Black
W
How about those valve cover gaskets!
1999 Black-N-Tan SVT Contour #291 Check out CD338.com:: The Premier Ford Fusion Site!
#1569375 05/15/06 03:47 PM
Stazi Offline OP
You ARE THE MAN!
Page 2 of 3 1 2 3
