Posts: 7,025 |
Im running a Lightning IAT. Youll have to solder it in the old the wiring, but it works.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 5,600 |
Originally posted by TC'd Swazo: Originally posted by MapOfTaziFoShoĆ¢ā??Ā¢: Should look like this i suppose.
Sweet, is it up and running??
That looks like a vortec to me? Even has the fuel pressure regulator. Stazi also has the aluminum UIM, no? Does look like his bay, but sans turbo.
Black 1998.5 CSVT
Posts: 10,015 |
That's offroad SVT not me. As if I'd go back to an inferior supercharger.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 5,810 |
Originally posted by Stazi: Originally posted by WorldTour: Why do you want a lightning IAT? IAT are basically a dummy Ford Sensor and don't differ a great deal from vehicle to vehicle.
It's got to be the screw in type. Our IAT isn't made to seal into a pressurized area.
EDIT: I ordered the screw-in IAT from Part's America. It's going to cut it damn close!
I just used a die to thread my stock IAT(after I filed off the plastic ridge that held it into the stock intake), cut a piece of rubber for a gasket, then drilled and tapped a corresponding hole in the intercooler after the exchanger right before the TB for mounting. Screwed in tight and has held very solid with no leaks.
Took about 30 minutes, cost = $0.00
Spending no money and little effort to make a better part/product/mod.........Priceless.
See My Mods
Posts: 352 |
Good idea, War... Nice one!
FYI the ADC kit has the IAT in the pipe that goes into the turbo- I suppose it would serve the engine better to have it after the IC...
Dan G. and his Cougar
Forged internal (Diamond & Pauter) full 3L, "Monster" Kinger F/I cut & P&P, T3/4 60 trim .82A/R ADC turbo, SPEC Stage 3, Torsen, Greddy Profec-B SPEC II, Apex'i Timer, Lots of Gauges!
Used to have: 3.0L SVT hybrid
Posts: 7,025 |
Originally posted by DanG: I suppose it would serve the engine better to have it after the IC...
Thats how mine is routed. Just tapped the Lightning IAT after the intercooler.
Jim Hahn
Posts: 4,970 |
That's where my IAT is, between the TB and IC.
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 10,015 |
Got the IAT and it connects directly into the stock connector.  I'm tapping and threading the intake manifold and putting it in there, just like the lightning setup. PS - motor is in, shopuld have it all done by tonight - tomorrow the latest.
AUSSIE ENDLINKS $70
Back In Black
Back In Black
Posts: 3,119 |
How about those valve cover gaskets!
Posts: 10,015 |
You ARE THE MAN!
AUSSIE ENDLINKS $70
