Posts: 241 |
'99 SilFro SE V6 MTX
Alpine CDA-9833, 12" L7, Pioneer 6x8's, Fidanza Short Throw, K&N Drop-In, Spec1 Clutch/Flywheel, WR Headers / Y-Pipe, TBz Cat, PRT Roll Resistors
Mods in queue:
Trubendz Res. Magnaflow Ex.
SVT UIM/LIM/Opt.TB
Posts: 674 |
They look to be about the same as the ones I just got. You still have to dremel/file down the back side to actually make it fit in the 98+ fender hole.
Posts: 241 |
Originally posted by hotdimmes: They look to be about the same as the ones I just got. You still have to dremel/file down the back side to actually make it fit in the 98+ fender hole.
ok, well im impatient, so i bought them, I'll report back with my findings.
Mods in queue:
SVT UIM/LIM/Opt.TB
Posts: 2,659 |
Should work post pics once you get them.
99 Contour LX
95 Mustang GT Convertible
97 Z24 Cavalier
Posts: 9,442 |
Those are gonna look sweet...I always wanted to get the smoked ones and never did....
Posts: 218 |
Now you just have to go to the dealer and get bulb sockets.Those won't have any as they are replacements for cars originally equipped with sidemarkers.
2000 Silver SVT
Posts: 241 |
Originally posted by tsSVT: Now you just have to go to the dealer and get bulb sockets.Those won't have any as they are replacements for cars originally equipped with sidemarkers.
They are in fact the correct ones, now i just need the bulbs / sockets like you said. I will post pics of the whole process step by sep once i get everything. I got the rectifying diodes at radioshack but i need to find somewhere with 30ohm 20watt resistors.
Mods in queue:
SVT UIM/LIM/Opt.TB
Posts: 857 |
I should rewrite the how-to. 5 watt resistors are adequate (industry standard 194 bulbs are ~3.8 watts). the ones you want are weatherproof sand-encased wire-wound resistors. two of these in parallel would work great:
http://www.radioshack.com/product/index.jsp?productId=2062292
50-ohm in parallel = 25 ohms (1/Rf = 1/R1 + 1/R2 + 1/R3...)
stack next to each other, wrap with a zip tie, twist the leads together, and proceed as normal. conveniently sold in a 2-pack too, one pack on each side and you're done.
Posts: 344 |
Those look to be the same one's I have. I really like them
