Page 2 of 2 1 2
#1567993 05/10/06 05:36 PM
Originally posted by pole120:
Originally posted by Tourige:
I know DEMONSVT has true duals among others.
show me where you can get some decent cats, mufflers, resonaters and a decent X-pipe for under 400 bucks.
Lets use his system's layout as a template shall we?
1) no cats0 $0
2) (2) Magnaflow res- $100 Justmagnaflow.com
3) (2) Magnaflow polished SST race series mufflers- $200 Justmagnaflow.com
4) (4) 180 degree u-bends form Jegs- ~60(don't recall exactly whaqt my total was)
5) Misc strait pipe and flanges locally- ~40(definitly no more than that)
6) Build and h-pipe (free)
7) Get to cut\weld\fit\repeat as necessary
I've also been doing some research and will be expermenting with using two stock SE exhaust piping ystems modified to run side-by side...because of ground clearance issues i'm going to have to go around my gas tank. The stock SE system is the proper size for tue duals(2").
Thats running an O/R H pipe, little different. I wonder what that would sound like
Originally posted by MxRacer:
Originally posted by RawBurt:
much like your weiner.
#1567994 05/10/06 07:08 PM
1) no cats0 $0
We'll find out once my shop is up and running
#1567995 05/11/06 02:50 AM
I believe demon has a h-pipe
#1567996 05/11/06 04:33 AM
O
OB1 Offline
O
I did mine just about exactly like pole is saying. I had $194 in magnaflows, Used 2 stock SVT systems JUST for the bends around the tank, built an H-pipe & used some glasspacks I had laying around. Car sounds barely louder than stock & slightly deeper. I'm not into loudness so Its perfect to me. $429 buck in it Tack on the change for the headers & you're still spending less than some of the catback systems.
I don't "mod" I just fix what breaks! 98 CSVT #2527 T-Red (Limping) 98 CSVT #2228 T-Red (Donor) 98 SE Sport ATX V6 (Running again) If swimming is good for your figure, explain whales to me!
Page 2 of 2 1 2
