FINISHED:
UIM/LIM gaskets, valve cover gaskets & spark plug tube seals, cleaned IAC, EGR gasket(never installed it last cleaning!
), rear O2 sensor replaced, new Autolite double platinum plugs, Autolite plug wires.
TO DO:
Remove Nitrous kit, swap out T/B threaded for nitrous w/ new 65mm T/B, replace front O2 sensor, install the brand new oil pressure gauge that Autometer sent me after I sent mine in for a broken needle, hose clamp one of the PCV lines that MIGHT be causing this intake leak I've had, repair a couple of chips in the Mirko splitter, and hopefully get my amp & rear deck sub hooked up. Oh, and possibly fix my non-working foglights.
Mark
