Page 1 of 7 1 2 3 4 5 6 7
Pole120 Offline OP
A message was left for all to see when my pride and joy BLKOUT left this world.....
Today i bring to you BLKOUT2....a true honor to her predicessor....
A VERY proud father...."Best SVT Contour of show" at the local SVTOA icebreaker
Originally posted by pole120:
I've changed my mind on the no-whoring till after SZ since i didn't get 60% of the ish done that i wanted to(mostly the highly custom stuff). Car was totaly stock when i bought it, i drove it 15 miles, parked it, and ripped it apart. I had to rush the car into daily service from a stripped shell when i totaled my SE . Spent a total of about 180 hours working only fri-sun in about a month and an half with the help of a very good friend. I got many of my mods done in the process but theres some things that just had to waite. I'll be posting more pics and my current mod list(ever growing) within the week.
I'm happy with where the car is at given the circumstances, however i had so much more in mind that the car's progress is still a bit of a disapointment for me personally.
Aesthetics:
-Pre-98 sails
-Elky mesh
-Painted oval with acid dipped and painted SVT badge in grill
-Dingless
-Mirko splitter
-Clear corners with clear turn signal bulbs
-Silverstar highs in lows and 2500k hyper yellow high beam bulbs
-Silver powdercoated engine and suspension components
-Tinted tails with painted chrome strip
-Mobil one factory fill badge
-Billet oil filler cap
-Shaved front keyholes
-Custom modded Pre-98 antenna base acid dipped and painted with S2000 antenna
-Carbon fiber IMRC cover
-Painted fluid tanks
Performance:
-KKM maf adapter
-K&N RU-3530
-Optimized TB
-Short shifter
-Solid 94A polyurethane front and rear roll resistors - want a set PM me
-MSDS Headers with solder-in MIL eliminators
-Optimized y-pipe
-Custom built 2.5" mandrel-bent Magnaflow y-pipe back exhaust
-Ford 9mm wires*
-Mobil 1 oil and filter
-Upper/lower intake system re-build
-Metal impellar water pump
Drivetrain:
-HMS built trans
-Quaife LSD
-Updated forks and syncros
-Tower mod to elminiate "sheared bolt" issue
-RP Syncromax fluid
-Spec 1 clutch
-17" Rev's soon to be wraped in 23540 rubber
Suspension:
-ES poly everywhere
-Konis painted black
-GCs with upgraded bearings
-Aussie bar with poly bushings
-Boxed subframe
-Spherical endlinks
-Tubular rear arms
Interior:
-Custom molded 2-5/8" oil pressure gauge in dash bezel
-Silver painted dash pieces to match engine and other parts
-Sony CD player with amp delete
-3 gauge pillar pod(coming soon)
-Trunk underside trim pannel
In the works at PRT's secret hideout:
-Boxed and modifed front LCAs with spherical bearings instead of bushings
-Tubular forward rear arms
-Custom modified CF hood painted body color
-Shaved jack-point covers
-Molded Mirko splitter
-Trangulated rear STB
-Pre-98 console with some tricks, dyed to match MNB interior
love it! The built in gauge is the hotness!
CEG road warrior
CEG road warrior
One of the sickest black SVTs EVER!
All it needs is tint and you're done!
I
I
Josh man your car is freaking bad A$$, i love it man. tint those windows now bro.
x10000000
Mark 1998 T-Red SVT -Needs more Go 1999 Light Prairie Tan, Se Zetec www.cardomain.com/id/tour4reak
Not a good continuation from where you left off - it's better. Very clean. Thumbs up.
Capitol CEG Classifieds Make an offer! 2005 GTO IBM - 337hp/336tq
BADASSSSSSSSSSSSSS! the amount of work you have put in it in such a short time is amazing. you should be very very proud of yourself. one of my favorites on the site. outstanding job man.
Oo (xxx)oO o xxxxxxxx o
Originally posted by Tour4reak:
x10000000
98 CSVT t-red 1737# cf1 Cowl hood Centerline Storms CEG Dragon Run- Oct 13-15 WTB- Vortech S/C kit/ADC Turbo Kit
i cant stop looking at the pics! awesome awesome.
Awesome, glad to see that the new car is out, looks great
