Goonz,
i'm happy you got it figured out
i had the same problem / fault code and got it solved by replacing EGR sensor (minor improvement) and plugs / wires which got things back to the way it should be.
i guess a good plugs / wires set is solution to almost everything :-) ... as someone here says always try the cheap and easy ones first
