Page 6 of 6 1 2 3 4 5 6
reseted the battery, nothing
im gonna leave in a bit to get new plugs..
And grease.
The clean the boots up really good.
And grease.
I did last time, bought that special boot cleaner and put that stuff on the plugs and in the wires..i'll do it again
so I took Pete's advice and bought Champion plugz from AZ..sure enough, they worked! I put that die-electric stuff in the wires and on the plugs, I put alot of it on too. Took my car for a 30min beat down where I was freaking redlining everywhere. The car was smooth with no hesitation and bucking. I couldnt believe it. AND it idle'd very well too now! no dipping..I think God is smiling down on me...for once
but im not getting too cocky, never know what ELSE might happen
but for now I feel relieved..sorta
Kick arse! Never thought I'd see the day. Told you it was one of the 2. I've never heard of anyone with issues with the APP764's though.
yea man! Im pumped, and hopefull nothin else will happen now
Cool. I'm glad you finally got it worked out. Now, go hit the redline a few more times!
Scott Mabe I WILL be Phil. 1999 Contour SVT, Tropic Green BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
Goonz,
i'm happy you got it figured out
i had the same problem / fault code and got it solved by replacing EGR sensor (minor improvement) and plugs / wires which got things back to the way it should be.
i guess a good plugs / wires set is solution to almost everything :-) ... as someone here says always try the cheap and easy ones first
Mondeo CLX 2.0 Mk2
