Posts: 1,029 |
I won't be able to check mine till I get home today, about 3:30 ish. If you want, I can check on mine and let you know where it goes (hopefully).
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
Posts: 5,345 |
Originally posted by Mid Life Crisis: Originally posted by Rogerm60: Originally posted by Goonz SVT: PLus I have this P0401 code that prolly means I need a new EGR
I don't remember anyone ever actually needing an EGR valve.
Clean the freaking intakes!
He just did recently.
Make sure the IMRC works! Both sides!
Are your cats good?
Probably not, as he just had headers installed. Read much??
Fuel problems can cause misses too. Injectors clean? Fuel pressure good?
How do the cylinders look inside?
This question is for Mid Life Crisis. Prior to Rogerm60's post, where did the words intakes or headers appear?
1996 V6 ATX 96K miles
Posts: 9,872 |
Originally posted by getsum111: I won't be able to check mine till I get home today, about 3:30 ish. If you want, I can check on mine and let you know where it goes (hopefully).
Well elky and I did check in his SVT..it grounds to the side of the power steering fluid resevior. However I have other wires grounded there. You know my car is really really weird compared to all you other SVT owners. I guess this is what you get with having an early build car..one of the first actually
Posts: 4,714 |
Originally posted by Tony2005:
So now we are supposed to go through all the 8558 posts of Goonz everytime he posts in troubleshooting?
W3rd. I can't keep straight what on my friends' cars, let alone half of CEG.
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 1,029 |
True. But since I was doing my UIM/LIM at the same time, I noticed his posts, and since he was still havin' trouble I guess I just remembered all his troubles.
Scott
Posts: 9,872 |
heres the ground wire im talking about..comes out from the firewall
Posts: 6,910 |
Originally posted by getsum111: ... I guess I just remembered all his troubles.
kinda hard to miss imho, if it isn't cars or planes all goonz talks about is how his car isn't running right
- 95 Mystique LS - Zetec/5spd
Posts: 8,445 |
goonbonzo, take a pic of that tube on the intake side too.
that ground wire in my car loops below the power steering res. and is attached to the fender, haroon already has a ground wire from somewhere else going to that location.
as for the tube... on the back side of the motor a few inches below the EGR he has an open tube that is maybe 1/8" ID. the open end is facing the drivers side. my car does not have this. i also have an E0.
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
