its to use on a mondeo 2.0 zetec with JRSC, i've just bought a Autogauge Air-Fuel meter i want to use the lambda on.
Didn't the guage come with an oxygen sensor? Check the manual and get whatever one that it recommends.
Or is it one of those guages that connects to your stock oxygen sensor? If so, return it. It is a narrow band guage. When trying to monitor your AFR, you really need a wideband oxygen sensor/guage. You can't just connect a wideband sensor to a narrow band guage. The readings would be useless.
I'm personally saving up for the AEM UEGO. It is a very good looking compact unit. It also has a 1 volt output so that you can use it's oxygen sensor in the stock location.
Others like the Innovate guage/sensor.
BTW, I think that most of the aftermarket AFR meters use a Bosch sensor.
HTH,
BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies--- +++JRSC M62 Under Construction+++ My big-a$$ mod list.
nice info cheers!
would it be ok to use this controller with the narrowband guage?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8046310923&fromMakeTrack=true
Unfortunately you can't. The narrowband guage only understands a 1 volt signal. A wideband controller puts out a 5 volt signal.
If you bought that controller, you would have to buy Innovate's wideband guage.
HTH,
BP
Moderated by  Loco4G63
