The shop may be right and you may need a new tranny but if it were me, I'd try all the last grasp straws first. What is your speedometer doing? Is it going to zero when this is happening? VSS issue ($40 part). When you go from 1-2, does it bang real hard? TSS issue ($25 part). Is it hunting for gears and seem to be in two gears at once? MLPS issue ($50 part).
VSS change by unisys.
"VSS (Vehicle Speed Sensor)
I had to change my VSS late this afternoon, so I thought I would walk you guys through the process on my Duratec/CD4E. It's really not all that bad, except unplugging the connector. My symptoms were pretty simple... Bouncing/in-accurate seedo and once that was bad enough, the tranny would not shift properly.
- Secure the vehicle, in the air, safely.
- Remove your air cleaner & tubing.
- Reach down, under the brake booster, and locate the VSS connector. You can actually see it better from the bottom, just no way to actually reach it from there. It will take some serious single handed twisting to disconnect this connection, but don't give up!
- From under the car, use a 5/16" wrench to remove the single bolt from the VSS retainer. * Note that this retainer looks like it is upside down, with a tab resting on the case of the tranny. Don't fret! This is normal, but be sure to replace the retainer in the same way that it was removed.
- Grasp the sensor body and lightly wiggle it out of it's location. Use gently force when wiggling, but apply steady pressure upwards. The sensor body should slide right out. Do not jerk upwards on the sensor, when removing it, or you will run the risk of gear coming off the end of the sensor. This is not a real big deal, since the gear itself is about an inch tall. Along with the added shaft that is part of the gear, the gear assy is probably around 4 inches long. You should be able to grasp it with a pair of crooked needle nose pliers, but it would be one hella tight fit!!
- Once the sensor is out of the case and you have removed the gear assy from the sensor body, use a rag to wrap around the body of the sensor base. This part of the sensor is metal, so we don't want to damage it. Use a pair of pliers and grasp the metal part of the sensor. LIGHTLY! Do Not Squeeze Hard!! Just apply a small amount of pressure here. And use a 1" wrench on the plastic part of the body and seperate the two halfs.
- At this point, you get simply reverse. But something that I should note here... There is a seal on the metal half of the sensor base. Be sure to inspect this seal closely or better yet, just replace it. Also, be sure to clean everything really good and lube everything down with CLEAN ATF before putting it all back together.
Part number of the sensor - F-F5RZ-9E371-BC
Cost of part - 44.67 + tax = 47.80
Part was purchused from local Ford Dealer
Reason for sensor replacement - Notice about a week ago that when traveling over bumpy roads, that my speedometer would fluctuate +/- 5mph. Monday, of this week, it progressivly got worse (of course) and the speedo would actually stay at 0 when taking off from a stand still, as well as droping to 0 when I let off the gas. In only 60 miles of driving, on that day, it managed to toast the ATF I had in there, which only had about 5K on it. Yes, I have also changed my ATF as well."
From Autozone for VSS change
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/cb/ad/0900823d801bcbad.jsp
Turbine Shaft Speed sensor issue.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=tranny&Number=257675&page=&view=&sb=5&o=&fpart=1&vc=1
and this
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1030582&page=&view=&sb=5&o=&fpart=all&vc=1
MLPS change.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1040336&page=&view=&sb=5&o=&fpart=1&vc=1
The tranny shift lever cable is below the car.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1116780&Forum=trouble&Words=shift%20lever&Match=And&Searchpage=0&Limit=25&Old=3months&Main=1116416&Search=true#Post1116780
and from Autozone.
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/d3/97/0900823d801bd397.jsp
