Posts: 1,119 |
That case is 170 dollars with 30 dollars in mail-in rebates. I was told already to watch for things like that. Not to mention those offers will expire by the time I get the PC and mail them in. And don't pick on my HD. lol I know it needs to be upgraded. but for now I'm gonna keep it until I get another 80 bucks to throw at it. Biggest issue right now is finding a different barebones because of the lack of PCI express. And decide if I want the AMD which seems like it well end up costing more then the intel. I'll probably have to end up dropping in another 100-150 dollars at this point.  So much for updating my PC and the Tour's suspension this summer. And the PC is probably the more important one to run right, because my tour's suspsension is wear, but not dead. And right now I'm only putting about 4k a year on because of living up at school. So it can be put off till next summer. *sigh* I'll go back and look at the AMD and intel boards and try to start over.
1998 SE Duratec V6 ATX
Ebay intake with K&N Filter
Trubendz Exhaust
Custom Hood
Posts: 4,155 |
Generally speaking, Win XP Pro and Norton Antivirus are memory whores no matter what machine I've ever used, but once they are fully loaded, I can load three scenes of 3d Max effortlessly (350,000 k's each) and the computer can work on those overnight without issue. I have 1.5 gigs of ram and a 2.2 ghz Athlon 3000+ processor.
Build your new PC geared toward upgradability, otherwise you're shooting yourself in the foot, as people have already said.
Posts: 140 |
I agree with everyone about going AMD 64-bit. However, if I was going to make that jump I would NOT get the Sempron for your needs/wants of being able to upgrade later. I'm not saying it's not a good processor, but everyone keeps saying you can upgrade the video/cpu/etc later on.
This is only half true. The Sempron is socket 754, which is already being abandoned, so you'll run into the same problem that is being mentioned about no processors being available. This is going to be the possible case for anything you buy now. In 2 to 3 years, don't expect the CPU socket to be around anymore.
That being said, I would still go for the Sempron 64, unless you want to be able to upgrade the processor later. If you want the upgrade option, I would suggest saving up a little more and jumping up to socket 939. It is at least more likely to still be actively around by your time frame.
Either way I would stick to going AMD 64-bit. You will be glad you did.
1998 Contour SVT
Toreador Red/Midnight Blue
3090/6535
1999 Contour SVT
Black/Prairie Tan
18/2760
1992 Dodge Stealth R/T TT
Metallic Beige/Tan
1989 Chrysler Conquest TSi
Red/Black Leather
Posts: 52 |
AMD Socket 939 is the way to go. Better than intel, 64 bit and can later be upgraded to a dual core.
Tan 98 Contour V6 ATX
-BAT intake, SVT exhaust, SVT suspension, Stazi brakes, superchip, opt TB, opt Y
"Max Power never abbreviates, each letter is as important as the one that preceeded it. Maybe even MORE important... no, as important."
Posts: 4,220 |
Re-use the case you've got, buy a Socket 754 Mobo for $90 and a Sempron 64 2800+ for $70, and you don't end up spending more than a few dollars more.
If you go 939, then you're looking at about $80-100 more if you re-use the case you've got.
The only thing to be worried about with re-using the case is the power supply. And frankly, even on that new case you were looking at, I wouldn't consider it's 300W power supply sufficient with a decent video card sucking power. You'd want 350-400, which I doubt the case you have now has. You could probably eek by with the 300 though.
2003 Mazda6s 3.0L MTX
Webpage
2004 Mazda3s 2.3L ATX
Posts: 1,119 |
Current power supply is a 300 watt. runs fine with current setup and no problems.
A new higher watt supply was on the wants list I was looking @ 400 watt supplies.
BUT on a side of fantastic news, I got a p1151 code on my way back to school. So I might be looking at an 02 sensor now as well. lol
But thats really not that big of an impact.
Trubendz Exhaust
Custom Hood
Posts: 7,117 |
Posts: 71 |
I would be very sceptical buying that barebones system. The power supply looks to be a rebadged deer and is highly over rated. It's probably 200w max and will adequately power the system until you upgrade. then it'll pop it's capacitors and you like most users will be scratching your head wondering why you get blue screens, phantom reboots etc..The MSI main boards are also notorious for popping capacitors and they skimp on power regulation using 2 instead of the usual 3 regulators. I'd buy everything seperate. Get a cheap ass case for $30, throw away the power supply and get a Seasonic 380w or larger. That's about $62 shipped and it has active pfc, all the proper connectors for future upgrades and good japanese capacitors. I've pulled a few of these apart and it's a very well made unit and inexpensive. As for mobo's and processors, I agree the Athlon 64 (preferably socket 939) is best. Even a socket 754 Sempron will be better than a Celeron (biased comment). Budget mobo's are a real crapshoot ATM as they tend to use chinese capacitors which can fail in 6 months to a year. You roll the dice and pray
Posts: 1,119 |
Originally posted by TourDeForce: Check it out.
Thats not to terrible. but it lacks PCI express. Beyond that, its looks pretty good. Also won't make rebates on it.
I'm waiting for my damn credit card bill to come so I can pay off my housing deposit. I'm holding a 500 dollar credit limit, so I can't order things until I send the check next week.
Trubendz Exhaust
Custom Hood
Posts: 584 |
Originally posted by Max Power: AMD Socket 939 is the way to go. Better than intel, 64 bit and can later be upgraded to a dual core.
Agreed. For maximum upgradeability, get a socket 939 mobo with PCIe and SATA.
E0 Silver Frost CSVT #3095/6535
Alpine CDA-9851
