Posts: 288 |
i havent seen a post like this so i'll start it off
- 143 spl .one crossfire xt212 ported box in a 2000 csvt.
-2000 csvt silver frost #1619
-magnaflow 14415
-optimized T/B & y-pipe
-superchips xgt1
-75mm proflow maf
-K&N RU-3530
-fsvt smart pump # 354Z-9H307-BC
-spec stage one, LSD
-low-tek,a/f,oil press.,volts
-B&M short shifter
-17" konig gt-r
Posts: 515 |
My last setup in my blazer hit 151 spl with 1 15" kicker L7 in a slot port box with a Directed 1100D amp and Alpine deck runnin 800 watts...Wires were Stinger 4GA kit with Silver Bullet RCA's
I just recently put a setup in my CSVT and havnt tested it but i wasnt lookin for anything large this time. Put in a 12" MTX 7500 with the Sledge Hammer ported box with MTX 3401D amp. The rms of the amp and sub are matched perfect at 400 and it sounds perfect. Wires are Stinger 4GA kit with Stinger Dream RCA's. Head unit is an Alpine of course.
Posts: 652 |
Can you buy SPL tester thingy's somewhere? If so, how much do they run for?
Champagne 1995 Ford Contour LX R.I.P. - 7/11/06
V6 2.5L 24v DOHC
Oversized System
Posts: 229 |
Usually, a good one is expensive. Talk to your local shop, they will usually allow you to test out on their's for a small fee (our local place is 10 bucks). That's the best way to go usually.
Morgan
1998 Contour GL
2.0L Zetec
Stock as hell for the moment....
Posts: 451 |
im waiting for the next competition in my area to find out the spl on my new setup. and i kno im using earplugs
2000 contour V6 ATX
BAT suspension kit, k&n filter, SVT TB, SVT UIM, SVT LIM, MSDS headers, MSDS Y-pipe, SVT dual exhaust, Custum burned ADC chip, 7000k HID's, 200 amp HO alt, custom gauges, and 17" rims
Posts: 288 |
- audiocontrol - audiocontrol.com
audiocontrol epic 150
audiocontrol epic 160
about 130-170 used on ebay about $300 new from an audiocontrol dealer only
its an spl meter . volt meter and an bass restoration unit thats patented its the $hit !!! i highly recommend it makes your system knock harder with the bass level and para bass controls. i've got one and love it !!!
-magnaflow 14415
-superchips xgt1
-75mm proflow maf
-K&N RU-3530
-B&M short shifter
-17" konig gt-r
Posts: 610 |
154 db with 2 12" arc audio flatlines in vented box built to spec, arc audio Foose Designs 1200.1
2002 Cougar
2.5 duratec/ mtx-75
85,0000
Mondeo ST-200 wheels/BFG KDW NT
black/black
Spec Stage 1
Torsen T-2
Trubendz 2.5 flowmaster dual exaust
apexi s-afc II
K&N FIPK
Posts: 229 |
Originally posted by ContourGuy9817: 154 db with 2 12" arc audio flatlines in vented box built to spec, arc audio Foose Designs 1200.1
Can I see pics? I wanna see me some Flatlines
Morgan
1998 Contour GL
2.0L Zetec
Posts: 610 |
sure, prolly be by the weekend, im still gettin everything set up, i need to mount it all down the box slides too much.
2002 Cougar
2.5 duratec/ mtx-75
85,0000
black/black
Spec Stage 1
Torsen T-2
apexi s-afc II
K&N FIPK
Posts: 3,264 |
I hit so hard she doesn't get up...
