Page 2 of 2 1 2
#1564865 05/06/06 05:10 PM
oh they fit just perfect. holes line up on the maf sensor and the ru3530 only needs like 3 turns to be tight
G/f's black 99se sport 5 speed 2 1/2 test pipe-custom cat back 3 single tip cai with kn3530 safc optimized tb 8mm plug wires spec stage 1 clutch svt front bumper
#1564866 05/07/06 02:47 PM
I made my MAF adaptor outta ABS pipeing and a piece of the old airbox for less than $5.00.
I cut the airbox end which had the mounting holes the MAF screwed into, and found two pieces of ABS pipe, and glued it all together. The airbox is made out of ABS as well and the ABS joiner/sealer/glue did an excellent job of bonding the old bit of airbox to the abs.
I too couldn't handel the idea of 40 plus bux for something so simple. It's been close to a year of daily 200KM trips into work and no issue whatsoever.
96 LX 3.0L MTX - Black/Tan K&N; 12lb F/W & uprated clutch 2.5" Pipe; SVT bits; Mystery Mod; Pull-tie Mod; UN-tuned Mod; 3rd Gear Synro-Crunch Mod 280K on the Shell, and 40ish on the Motor... 1/4 mile?? Yeah, it's a fun daily driver...
Page 2 of 2 1 2
