here are the specs for the pioneer
Key Features
Amplifier Type Dual Channel
Bridgable Bridgable
RMS Power at 4 Ohms 80 W x 2
RMS Power at 2 Ohms 120 W x 2
Performance
Frequency Response 10 Hz - 50000 Hz
Signal to Noise Ratio 102 dB
THD at Rated RMS Power 0.04 %
Crossover / Equalizer
Bass Boost With Bass Boost
Bass Boost Frequency 60 Hz
Other Features
MOSFET Circuitry Yes
3 Way Ready Yes
Dimensions
Width 10.38 in.
Depth 10 in.
Height 2.38 in.
Miscellaneous
Product ID 20742671
do you still agree that i should bridge it at one channel and turn the gain down or get an 8 ohm sub and bridge the two channels? thanks for your input.
and with that in mind...how do you like this 8 ohm sub by kicker, the Kicker Comp C88 shown here...
http://www.cardomain.com/item/KIC05C88
