Page 2 of 2 1 2
johnoh Offline OP
Tony thanks a lot I bet you are right. What do you suggest I do next?
'95 Contour GL 2.0l automatic, 110k miles
It sounds to me that you don't have a factory keyless entry, but the aftermarket, dealer installed Ford alarm.
If you had factory keyless, your remote would look like this:
-4 buttons
-black unlock button
-black lock button
-red panic button
-blue trunk button
I'm assuming that the dealer installed alarm had the anti-theft cut off hooked up to the fuel pump instead of the starter like it should. I'm also assuming they didn't wire it correctly because if they did, unlocking the car with the key should also disable the anti-theft system. What you need to do is find the alarm brain, find the anti-theft wire, and trace it to where the alarm wire is wired into the fuel pump cut-off switch and find some way to stop the alarm from controlling the fuel pump.
If you aren't comfortable with this, take your car to an electronics shop and ask them to troubleshoot and disable that feature.
Originally posted by red99sesport:
.... What you need to do is find the alarm brain, ....
The "brain" will usually have a "click" or "whirr" sound when you lock or unlock using the remote. Most times it is under the drivers' side (close to the steering column) for an aftermarket system.
As suggested by red99seport, if you aren't comfortable with messing with the wires, "take your car to an electronics shop and ask them to troubleshoot and disable that feature."
Originally posted by johnoh:
My bet is you are under 25. Read more and write less.
You wanted an answer and I gave it to you. I'm 31 thanks and know more about these cars then most should. My first post nailed your issue. Everyone is responding in more detail. I get to the point. Your issue is incorrect wiring and nothing to blame on the inertia switch.
E
E
Look how far I can pee.
MUST SELL - ECM computer new for a 98 V6 mtx + pats Now trolling in a Red Nissan 4 x 4
Page 2 of 2 1 2
