Page 2 of 2 1 2
#15627 05/16/02 01:17 PM
F
F
I added injector cleaner and went through a tank of gas-still does it.
#15628 05/16/02 04:01 PM
H
H
Originally posted by Firefighter151:
What is the IAC and how easy is it to change
On the back of the Intake manifold, almost against the firewall - you can see a indention/channel that starts right after the trottle body and goes straight toward the back of the car to the idel air controler ( IAC ). Only two screws, ones easy & the other hard...if you think this is the prob. You can always try to just clean the IAC w/throttle body clnr & see how it turns out.
#15629 05/16/02 04:03 PM
H
H
Originally posted by Hi-Liter:
[b]What is the IAC and how easy is it to change
On the back of the Intake manifold, almost against the firewall - you can see a indention/channel that starts right after the trottle body and goes straight toward the back of the car to the idel air controler ( IAC ). Only two screws, ones easy & the other hard...if you think this is the prob. You can always try to just clean the IAC w/throttle body clnr & see how it turns out.[/b]
You can always reset the PCM too - maybe a fresh start would help
Page 2 of 2 1 2
