Posts: 1,421 |
I got a code P0401, so I cleaned out my TB and the EGR ports behind the TB. No more codes, but now I have throttle hang all of the sudden. I have never had any throttle hang problems before...never. And now just because I cleaned the TB...  I cleaned my IAC before this happened, and just cleaned it again just to be sure. Why would a clean TB and cleaned EGR ports cause TH? I am so confused. I guess I could do the common TH fix, but I may still lose sleep over why this suddenly happened. Also, could I substitute the copper plug with mesh wire folded over the inlet on my intake pipe and the rubber hose over top of it? Isn't the objective to restrict airflow? Just curious. Thanks in advance.
99 Black SVT -3L Hybrid w/.5mm overbore, Spec clutch/flywheel, MSDS, BAT intake, K&N open, 17'Konig Tantrums, DMD, Opt. TB & Y, Powerslots, Bassani w/ magnaflow res.
96 SE MTX- "The War Wagon"
"I'm in love with my car..."
-Queen
Posts: 1,788 |
Ironically, immediately after I did my UIM/LIM gasket replacement including TB and IAC cleaning, Mr. Moose came to visit.
I had to do the TH fix to send him back to the woods...
I didn't loose any sleep over it, just picked up the cap, drilled the hole, installed it, and gave the keys back to my wife (it's her DD).
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 1,029 |
Originally posted by projectSHO89: Ironically, immediately after I did my UIM/LIM gasket replacement including TB and IAC cleaning, Mr. Moose came to visit.
I didn't loose any sleep over it, just picked up the cap, drilled the hole, installed it.
Same here.
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
Posts: 1,421 |
Has anybody formed a hypothesis as to why this happens after TB, UIM, LIM, and IAC cleaning? It's just wierd man, and it's frustrating. I might try a different method than the copper cap, like what I mentioned above or maybe a hose clamp.
-Queen
Posts: 530 |
Originally posted by CLASSVT: I might try a different method than the copper cap, as mentioned above. Just to see if it works, and save me some $.
Yeah cause those copper caps are like $.35
Originally posted by MapOfTaziFoSho: Can u ask him to measure his shaft and compare it to your shaft?
Posts: 1,421 |
 Edited to remove rediculous statement about saving $. But I am curious about trying different methods, not sure why. But if I could put some mesh around the inlet, and the hose over top of that, I wonder if that would work. I also read a post where someone mentioned tightening a hose clamp to pinch the hose. Either way I can always revert to the copper cap if it doesn't work.
-Queen
Posts: 3,637 |
Originally posted by BlackBirdRacing: Originally posted by CLASSVT: I might try a different method than the copper cap, as mentioned above. Just to see if it works, and save me some $.
remember your on a contour forum, were all cheapasses (minus the Turbo guys)
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 530 |
your right...
We have a simple problem here...
The simple fix is right in front of us (the copper cap)
But what the hell I'm going to spend hours of my time trying to figure how I can do it cheaper than $.35.
Your NUTS!!
Posts: 1,421 |
OK, so the local harware shop looks at me like I'm crazy when I ask for a 1/2 inch copper cap with a hole in the middle. I tried the hose clamp, and it didn't do a damn thing. I guess I'll have to make the trip to Home Depot later. I was convinced the hose clamp was going to work.
-Queen
Posts: 4,051 |
Originally posted by CLASSVT: The reason I was trying to figure out a different way to do it, was because the local harware shop looks at me like I'm crazy when I ask for a 1/2 inch copper cap with a hole in the middle. I tried the hose clamp, and it didn't do a damn thing. I guess I'll have to make the trip to Home Depot later.
You don't buy it with a hole in the middle. It's just a plumbing cap to go onto a pipe. You drill the hole yourself.
