Page 2 of 2 1 2
#1561824 05/01/06 10:28 PM
Originally posted by CLASSVT:
OK, so the local harware shop looks at me like I'm crazy when I ask for a 1/2 inch copper cap with a hole in the middle.
HOLY F*CKING SH!T.
PLEASE TELL ME A CEG MEMBER WITH A 3L UNDER THE HOOD, DIDN'T JUST SAY THAT!!!!
Originally posted by MapOfTaziFoSho:
Can u ask him to measure his shaft and compare it to your shaft?
#1561825 05/02/06 02:11 AM
CLASSVT Offline OP
HOLY F*CKING SH!T.
I must have missed the part of the how-to where it said that drilling was required. I thought for some reason they just came that way. Just 'cause I got the goods under the hood doesn't make me a mechanic, or a hardware expert. However I learned from the butch at Home Depot that such a thing does exist, so I must not be completely retarded. It's called a compression cap, and they didn't have any in the size I was looking for. So I got two 1/2 inch copper pipe caps and was going to just drill the holes myself with the respective drill bit sizes, and try each to see which worked better. However, on the way home I noticed that my throttle hang was not as bad as before, hanging at a lesser rpm for a shorter amount of time. So I drove around for an extra half hour, and now my throttle hang has gone away on its own! I only hope that it's fixed for good, and I won't have to drive that long each time before it goes away. So I'm happy to say the least.
99 Black SVT -3L Hybrid w/.5mm overbore, Spec clutch/flywheel, MSDS, BAT intake, K&N open, 17'Konig Tantrums, DMD, Opt. TB & Y, Powerslots, Bassani w/ magnaflow res. 96 SE MTX- "The War Wagon" "I'm in love with my car..." -Queen
#1561826 05/03/06 03:51 PM
What size of holes did you drill in copper caps?
00 Mystique LS V6 ATX 57K miles K&N air filter TH Fix B&M 70268 Atx cooler
#1561827 05/03/06 04:09 PM
IIRC, everyone's can be different, but mine was a 7/32 I think.
Scott Mabe I WILL be Phil. 1999 Contour SVT, Tropic Green BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
Page 2 of 2 1 2
