Posts: 9,872 |
yea but heres the weird part, the grinding noise doesnt come from the wheel, it comes from the center. Almost feels like somthing not alligned and its a metal to metal grind.. ![](/ubbthreads/images/graemlins/confused.gif) im soo lost, and the vibrations now, i dont understand whats causing those..
Posts: 71 |
If it wiggles side to side only, it's usually a tierod end. Up and down and it could be the ball joint. Rocking it in any direction and you have a bad bearing. That coupled with your grinding noises makes me think it's the bearing. A bad CV joint will grind and click but won't cause the wheel to rock as is the case here.
Posts: 9,872 |
Originally posted by Mustang: If it wiggles side to side only, it's usually a tierod end. Up and down and it could be the ball joint. Rocking it in any direction and you have a bad bearing. That coupled with your grinding noises makes me think it's the bearing. A bad CV joint will grind and click but won't cause the wheel to rock as is the case here.
My LCA's were recently replaced not too long ago so I have new ball joints and what not..tie-rods according to elky at the time seemed fine so im pretty sure it must be the wheel bearing..
Posts: 562 |
Nice, thanks for the clarification!
'99 Spruce Green SE "Sport" 'Tour, 2.5L MTX...80K and running like it just rolled off the lot.
Tryin' to add an extra .5L ASAP
Posts: 71 |
Hate to be the one bearing you bad news (bad pun). NAPA has them in stock, SKF FW177 for $44.40. But you gotta find someone to press it in. In that how-to thread, you can buy the whole assembly for $160.00. I dunno if that'd be cheaper than having someone press it in for you. I'd be willing to do the work for free but the drive may not be worth it.
Posts: 9,872 |
Originally posted by Mustang: Hate to be the one bearing you bad news (bad pun). NAPA has them in stock, SKF FW177 for $44.40. But you gotta find someone to press it in. In that how-to thread, you can buy the whole assembly for $160.00. I dunno if that'd be cheaper than having someone press it in for you. I'd be willing to do the work for free but the drive may not be worth it.
is there a special tool for pressing it in?
Posts: 9,065 |
LOL...so you thought poles mounts made your car a bad drive and you really had a bad wheel bearing! OWNAGE!
Posts: 71 |
Originally posted by Goonz SVT: is there a special tool for pressing it in?
A bearing press. It's a real tight fit so trying to hammer it in isn't a good idea
Posts: 71 |
Originally posted by MapOfTaziFoShoĆ¢ā??Ā¢: LOL...so you thought poles mounts made your car a bad drive and you really had a bad wheel bearing!
OWNAGE!
I haven't gotten that far yet Mr. hard core cger. Ask me after I've received the goods. I suggest you post your comments in the proper section and stay on topic here.
Posts: 9,872 |
OWNAGE!
the pole mounts was really rough on my car, it still shook on the highways regardless of the mounts..The mounts just made my car loud and very rough..
