Posts: 1,421 |
I was taking my intake apart to clean some stuff, and I noticed something that made me wonder... On my BAT intake pipe, the largest inlet (towards the EGR) is not completely open where it is welded to the pipe itself. It almost appears that the inlet was completely closed off from the pipe itself, and then a quarter-inch size hole was drilled to let the air pass through. The opening is probably half the size of the inlet itself. Is this correct, or should I drill it out to be the full size of the inlet? It's been this way for years, and I guess I never noticed.  Thanks in advance.
99 Black SVT -3L Hybrid w/.5mm overbore, Spec clutch/flywheel, MSDS, BAT intake, K&N open, 17'Konig Tantrums, DMD, Opt. TB & Y, Powerslots, Bassani w/ magnaflow res.
96 SE MTX- "The War Wagon"
"I'm in love with my car..."
-Queen
Posts: 1,421 |
Anyone? Beuller?...Beuller?
-Queen
Posts: 21,653 |
If it ain't broke then dont go messin with it.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 853 |
it might not be broken, it also might have never been right from day one.
The pipe i just installed was from GMK the holes were not very clean so i ran a drill through them to clean up the holes. Did it help or hurt the car i am not sure yet as i haven't driven it because of being away at school.
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998
WR Headers GMK CAI
Blaupunkt system fiberglass tweeter pods
L.E.D. tail lights in the works
Posts: 1,421 |
Yeah well this one isn't dirty, it was just never bored to the same width as the inlet. Doesn't seem right. I'm not sure what to do. If anyone has a similar BAT intake pipe, or any other intake pipe for that matter, maybe check yours out and see if it's the same size opening.
-Queen
Posts: 566 |
Leave it alone, it is supposed to be that way. It says so in the instructions that come with the unit. The smaller opening is supposed to cut down on the moosing acording to the documents that came with the unit.
Bob Johann
SoundQ SVT
1998 T-Red SVT Contour #3088
2001 IASCA Pro Street 1-600 Champion
2002 SLAP Pro Street 1-600 Champion
2002 MECA SQL Master Class Champion
2003 IASCA StreetX 1-600 Champion
2005 SLAP Expert Street Champion
Posts: 1,421 |
Thank you SoundQ SVT, as I never had the instructions since I bought it off of Y2KSVT when I first got my car.
-Queen
