#1560282 04/28/06 02:10 PM
E
E
Well I got some new codes from the computer 335 and a 332 and now there is a knock from the motor when you let off the gas. Could this be because of the codes or is the motor due for a rebuild now?? If the motor is due for a rebuild I am parting out the car. Its a 95 Mercury Mystique with the 2.5 v6 and a 5 speed trans
#1560283 04/28/06 02:58 PM
Like rod knock?! Considering your car does not have a high C/R I highly doubt the car is knocking unless you are mixing water and gas.
#1560284 04/28/06 03:16 PM
E
E
Well what do you mean unless I am mixing water and gas?? It sounds like it possibly could be a rod knock but thats why I gave the codes I got from it and like I said it does it when the rpm's are coming down after reving it.
#1560285 04/28/06 03:16 PM
I think Pete is right...
Your codes are
332 (R,M) EGR did not open/respond during test or if memory code, did not open intermittantly
335 (O) EGR feedback signal is/was out of range
Sounds like you need a new EGR value... Very well could clear up your problem.. Also try a bottle of Fuel stabilizer... Something that is designed to eliminate water from the gas tank and so on... Couldn't hurt...
#1560286 04/28/06 04:00 PM
E
E
I will give this a try but would these things really cause a knocking type sound from a engine?? Cause if this is all it is then I would be very happy.
