Posts: 530 |
My bumper has become extremely loose.
It wasn't right when I bought it but it has gotten worse.
Does anyone have an exploded diagram of the SVT front bumper.
Also mine really doesn't have any supports. Any pictures of underneath would help also..
Originally posted by MapOfTaziFoSho: Can u ask him to measure his shaft and compare it to your shaft?
Posts: 7,025 |
Theres 2 bolts on either side that hold it into the fender. There should also be one metal rod on either side that secures the lower part of the bumper.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 21,197 |
Any tabs under the grill? Can't remember.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 8,445 |
i think there are 3 push in plastic things under the grill.
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
Posts: 530 |
Originally posted by beyondloadedSE: Theres 2 bolts on either side that hold it into the fender. There should also be one metal rod on either side that secures the lower part of the bumper.
deffinetly don't have any metal rods...
I guess I better call Bill @ team ford.
Posts: 4,051 |
Originally posted by ElKy da Stalker: i think there are 3 push in plastic things under the grill.
Nope. 2 under the grill. 1 at the bottom of the bumper connected with a plastic bracket.
The metal rods are only on 95-98 bumpers unless added after.
Before doing the ones under the fender, you must disconnect part of the wheel well liner to get access to the bolts. 2 screws in the wheel well, one screw at the edge of the bumper, and 2 where the liner meets the lower air deflector.
So in total 14 screws/bolts and 3 plastic clips. Sounds hard when you read it, but once you do it once, it's cake. I've done it too many times now.
Posts: 710 |
You can also add another bolt right next to the one in the fenders... there's a hole and threading for it, just need to add the bolt. That also helped stabilize my bumper cover.
morbid
2000 Contour SVT (black)
