#1558958 04/26/06 07:19 PM
H
hoger29 Offline OP
H
My 96 contour atx 124,000 has been ticking loudly lately. It kind of sounds like the marble in a paint can. It will go away slightly upon acceleration, but I can hear it come back as the rpms begin to fall back down.
It did go aleast 8,000 without a oil change, but I recently ran a little berrymans through and changed oil and filter. this helped somewhat but it is still quite noticable.
Does this indicate that a lifter is bad or stuck? what can I do to diagnose this problem as my haynes repair manual doesnt really give me any ideas.
#1558959 04/26/06 09:04 PM
join the club.
-Contour's dead, but is being revived...
Originally posted by CSVT1214:
Originally posted by ford zetec2:
after than, what do i do with the 98 short shifter? do I place it in there like it is?
Stick it in your butt and rotate.
#1558960 04/27/06 06:39 AM
Originally posted by blakjak:
join the club.
What does "join the club" mean? Is that ticking a common problem on tours? Anyways, I had a similar noise that slowly when away upon acceleration and I could not figure out what it was for the life of me. I took it to a shop and it was a slight exhaust leak at the flange after the cat. Easy fix. May not be your problem, but it is a thought.
For Sale - 96 Tour Sport 2.5L MTX with SVT Exhaust, pre 98 trunklid with newer Contour Sport spoiler instead of lip spoiler, newer Contour sport rims. Newer paint job. Brand new floor mats. Rust Free! PM me for details and pics.
#1558961 04/27/06 04:13 PM
H
hoger29 Offline OP
H
By slight leak do you mean at a connection, was it a gasket, how did he determine it was leaking.
Does anyone know how to check for a leaking exhaust?
I hope this is an easy fix as well, because my car does not burn oil and only has some minor suspension issues.
#1558962 04/27/06 08:47 PM
join the club means i have the same problem. looks like valves for me.
CLICKY!!
#1558963 04/27/06 09:31 PM
H
hoger29 Offline OP
H
I read your link and I do not have an oil problem other thatn it hadn't been changed for many miles. It does not use oil as it was not even a quart low when I changed it.
I was wondering if there is any other suggestions on what it might be or if there is any way to diagnose if it is a lifter.
#1558964 04/27/06 10:37 PM
a buddy of mine just got the same thing today, same everything.
Originally posted by MxRacer:
Originally posted by RawBurt:
much like your weiner.
#1558965 05/03/06 02:28 AM
H
hoger29 Offline OP
H
i noticed tonight that the ticking is barely heard after the engine is warmed up, and it also seems to be quieter when it is in gear as opposed to park.
#1558966 05/03/06 04:28 PM
Originally posted by hoger29:
...I do not have an oil problem other thatn it hadn't been changed for many miles. ....
Does it still sound after you changed the oil?
#1558967 05/03/06 07:24 PM
H
hoger29 Offline OP
H
Yes, it does still make the noise after the oil change. It sounds very similar to a marble in paint can. It quickens with acceleration and gets loud upon decelleration. It does practically disappear after the engine has been up to operating temp but there is still something there.
