Page 4 of 4 1 2 3 4
#1558690 05/02/06 04:35 PM
yea i read that i was just talking about the contour. the camaro will be fine with it i think , when i get that program on here i belive it will be a big hit
#1558691 05/02/06 05:22 PM
Cool, I would like to see it. ARRRGH!!
Fifteen men on a dead man's chest... Maverick Machineworks is open for business!! Tell me what you need and I can make it!
#1558692 05/03/06 01:33 AM
CSVT#49 Offline OP
Awesome. Can't wait to see the results.
I just wish there was a way to figure out what the trim is. My brother came by and was trying to tell me it looked like a T3/T4.
-Mike 98 Contour SVT Toreador Red #49 of 6535 Built on 3/25/97 WR Headers, Borla Cat-Back, Torsen T2 LSD, K&N Short Ram, S-AFC and Focus Shift Tower 85 Camaro 1969 358ci, 97 TA interior, 91 Z28 GrdEfx and Aero Wing 255rwhp
#1558693 05/03/06 02:22 AM
W
W
You won't know ANYTHING until he checks the trim sizes and finds the map. It MAY or MAY NOT work.
#1558694 05/05/06 05:54 PM
CSVT#49 Offline OP
I found some more information about the engine this came off of. It's a lot smaller then I though it was, only 5.98L.
4-stroke 6 cylinder electronic turbocharged Diesel
Ratings
Gross Power @ 2200RPM 150Hp
Dimensions
Bore 3.94"
Stroke 5"
Displacment 5.98L, 365 cu. in.
#1558695 05/06/06 03:10 PM
W
W
what is the that the engine made max torque at? And the boost pressure at that max torque rating?
If you get that then we can calculate max airflow at the most efficient point and then see what that would translate to on another engine.
#1558696 05/08/06 08:56 PM
CSVT#49 Offline OP
Engine
Gross Power 150 hp / 112 kW
Engine Model Cat�® 3056E ATAAC
Net Power - EEC 80/1269 143 hp / 107 kW
Net Power - ISO 9249 143 hp / 107 kW
Net Power - SAEJ1349 142 hp / 106 kW
Bore 3.94 in / 100 mm
Stroke 5 in / 127 mm
Here is what I could get from he Caterpillar website to share with you guys.
I'm still looking for boost data, but I doubt I'll find it.
#1558697 05/09/06 03:17 AM
W
W
Well, from looking at the figures I'm thinking that unless this turbo is running 1.5 bar or more boost, then it wouldn't be worth your time. This is assuming the turbo is sized efficiently to the tractor engines size and desired rpm range.
So lets think it through:
It maxes out at 2200 rpm with max torque attained at 1400 rpm. It is a four stroke engine so you take displacement times half the rpm range and find out that the engine moves around 240 cfm of air at normal atmospheric pressure. It is hard to determine how much of the torque curve sloping off is due to the engine design and the massive rotating assembly and how much is from turbo efficiency range. I'd guess the former.
But anyway, back to the calculations.
240 cfm at 0psi boost. Lets assume the tractor is running 20psi boost, that is a pressure ratio of 2.36 or 1.36 bar above atmospheric.
2.36x240cfm = 566cfm
This is about the cfm I was using to push about 320 wHP on my car.
So until you get the boost pressure the turbo is run at, you won't know. You don't have a map so what I am doing here is a qualitative comparison of exhaust and intake flow volume of two different engines.....because the turbo doesn't car how many cylinders or the rpm range, it only is relevant based upon how much exhaust is flowing through the turbine, and the compressor is only concerned with the pressure and volume flow of the intake.
Or look at it this way:
A 6 liter diesel engine (2x larger than the 3L engine) operating at 2200 rpm max(1/3 the rpm range of the 3L engine) will move about 2/3 the airflow that a normal 3L engine would at max rpm, comparatively speaking. So unless the turbo is sized with for significantly higher pressures on the diesel than those that you will use on the 3L, or the 5.7L, then you are wasting your time.
Incidentally, your 5.7L engine will push about 450 cfm at max rpm and 80% VE. The 3L will push about 300 cfm at about 90%VE.
So when you find out the boost level of the CAT engine, then use this explanation and the math to see if the turbo would support one of the above engines....and if the boost is it used at is high enough then you have a good shot of it working fine.
Page 4 of 4 1 2 3 4
