Page 1 of 3 1 2 3
Have a article on the Oil Starvation problem with the SVT oil pans..........I am one of few who blew there engine from the oil starvation........its kinda cool how they say will fix it......
-Mancho- cars name is Connie
99 Silver Frost SVT #1986
k&n filter with cut out box
true duals w/ flows smile
Ground Controls with 17's mille miglia ...
Hightower headlights
15.4 at 90.29 at Milan dragway before the true duals smile
wow...but I thought it was not an oil pan issue as much as "not enough oil" issue?
How about some details?
it really isnt an oil pan issue but when you rev your car about 5 grand ( something around that) the oil pan has less than 1/2 quart of oil....so they make a kinda trap door in your oil pan to fix the problem....I read it at Rit ad today so i was reading real fast......but its goes along sorta like that........
How in the world is a trap door going to solve what they believe to be an oil pan capacity issue?
Besides, if it is the SHO Shop talking in that article, it has been covered in the last few days and a few times in the past as well. I doubt that SHO Shop did their own testing to determine how much oil is in the pan (just regurgitating what they read here, which I personally don't believe anyway - crank harmonics killed my last engine, not oiling).
And their pan kit requires mods to the existing pieces for the dipstick to work properly. I know; I have one.
Did you see David Z's post a while back on the fact that he thought all 2.5L V6's from 2001 on got the extra 2 oil returns in the head that the 3.0's have always had?
http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic&f=49&t=000183&p=
Seems like if ford would spend the money to redesign the block and head casting on what is more or less a "limited use" engine here in the states they must have thought it was a real problem.
It appears they were to cheap to put a ~20 dollar more expensive (guestimate of actual dealer price vs the stock one at 45 dollars) DMD on the US tours because all the cougar engines were already built, but were willing to redesign the castings for block and heads to give it an extra oil return. That should tell the intrested consumer something about the extent of the problem.
This of course is idle conjecture on my part based on Dave's one post.........
97 SE MTX, KKM, UR UDP, 19# Injectors, SVT TB, SVT UIM, SVT Flywheel, Grizzly Street Clutch, Upgraded motor mounts, mystifed precats, brand new main cat, SVT exhaust sans resonator, 205-55-15 Dunlop SP5000's
154hp / 156 tq before the SVT exhaust, SVT dual honed upper and swapping the mystery main cat for mystery precats.
My Profile
H
H
I said the Same DAMN THING 50 YEARS AGO- and nobody believed me!
HA - when I say something- its because I know what Im talking about!! mad
BTW- thats Roush talking about the 5 grand and 1/2 litre- I know because I talked to one of the engineers on the project about 7 MONTHS AGO! cool
so listen when that little birdie says to do something- mad
'98 SVT #2253
Currently DEAD!
Cobra Paradise
Thanks Horse wink I for one took your word for it and went out in the garage and added 1/2 quart of Mobil 1 right away. When I was due for an oil change I added 6.5 quarts of oil and now I know what the "real" full line is, thanks for info! I for one appreciate when someone on the inside actually helps us here, instead of being an insider and telling us your an insider, over and over and over again :rolleyes: A word of advise to you "insiders" w/o any helpful info, please replace the ribs you removed, thanks!
Roger R
SVT/SHO Society SE MI rep
2000 CSVT #1253 of 2150
silver frost/midnight blue
2-8" dark blue racing stripes
Mequiars...simply the best!
"...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4"
USMondeo@aol.com
I thought it was putting 6 quarts not 6 1/2.... confused doesnt our cars suppose to only take 5.8 quarts or something like that....if anyone knows please help.... smile thanks
I've been having my mechanic add an extra quart everytime I get the oil changed from the first time I heard about this... been working fine I guess... No sweeping right turns followed by a blown engine
98 V6 Lots-o-mods SOLD
88 Daytona Shelby Z TII (The beast)
87 Daytona Shelby Z TII (Holy 20 psi of boost batman!)
Mods- 3" Downpipe, Hi-Flow cat, 3" mandrel bent exhaust with Dynomax Ultra flow. Manual boost controller, TurboXS blowoff, 5th injector, large canister wastegate, Nitrous Express go-fast-be-happy kit, ported exhaust manifold, ported intake manifold, upgraded motormounts, eibach springs, strut tower brace. Oh and 20 PSI to boot.. my oh my...
i've been slightly overfilling when topping off the oil for the last couple months or more cool
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
Page 1 of 3 1 2 3
