Posts: 1,882 |
Originally posted by RogerB: Originally posted by IRingTwyce: Originally posted by RogerB: I thought it was only the early production run, until the old LCAs got used up.
Those are the 4-bolt, right?
Yup.
thought so. Isn't the rear sway-bar on the 95 larger than the one on the 98's? SE, not SVT.
I think my 98 would like an older sister, so I've started poking around looking for 96 V6 MTXs....hard to find.
Posts: 4,051 |
Yup.
Well I'm almost positive my friends 98.5 SVT (Built May 98) has 4 bolt.
My car, which is a 98 (Built April 97) has the 4 bolt for sure.
Someone else can maybe confirm when Ford made the switch. As pricey as the 4 bolt LCA's are, everything I read on here says the 4 bolt is a superior design to the 2 bolt.
Posts: 6,910 |
Originally posted by Tourige: Even the gas was heavy on that car, someone has to know what im talking about on this one, the gas pedal is just NUTS, so much resistance, i LOVE it.
did it have TC? if it did the throttle cable runs around just about the whole outside of the endin compartment as the TC motor was behind the passanger head light, also if you want to keep a 95 moving you need to keep your foot on the gas ... it might have also been an issue with the throttle cable as there was a recall on it for sticking gas pedals
- 95 Mystique LS - Zetec/5spd
Posts: 6,910 |
What's in the "light package?" I can't think what else I'd light up in my car. I've got lights at my feet, flood and map lights on the ceiling, and lights in the door handles.
the light package included the door handle lights and the key lock lights, also I believe it included the glove box light too, it also included the window switches
Posts: 3,867 |
I have all that, too, except for the keyhole lights. I think this has been discussed on here, before, and we figured out the only thing decontented in 96 was the keyhole light!
Function before fashion.
'96 Contour SE
Posts: 3,867 |
Originally posted by IRingTwyce: Originally posted by RogerB: Originally posted by IRingTwyce: Originally posted by RogerB: I thought it was only the early production run, until the old LCAs got used up.
Yup.
http://www.contour.org/FAQ/FAQ.php?s=specs
'96 Contour SE
Posts: 1,882 |
Originally posted by RogerB: Originally posted by IRingTwyce: Originally posted by RogerB: Originally posted by IRingTwyce: Originally posted by RogerB: I thought it was only the early production run, until the old LCAs got used up.
Yup.
Man, it's been so long since I've browsed the regular site I didn't even think to look there! Thanks!
Posts: 3,637 |
Originally posted by BrApple: Originally posted by Tourige: Even the gas was heavy on that car, someone has to know what im talking about on this one, the gas pedal is just NUTS, so much resistance, i LOVE it.
No, no TC for me, Just the gas is REALLY heavy, heavier than ANY car ive ever driven, its crazy.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 3,637 |
Yup.
Yea im pretty sure the rear sway bar was equal or bigger than the SVT rear one (20mm or so)
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 3,570 |
Originally posted by RogerB: Originally posted by BrApple: Originally posted by RogerB:
I beleive that is correct
