Posts: 345 |
Check out my new mod! I had to run a wire from the front ones to the back. Then cut the brake/blinker wire and re-wired the brake light to the third brake light in the back window. So now the brake light will only turn on when I hit the brake or if the lights are on. You like? I like!
"I guess of all my uncles, I liked Uncle Cave Man the best. We called him Uncle Cave Man because he lived in a cave and because sometimes he'd eat one of us. Later on we found out he was a bear"
http://www.cardomain.com/ride/586498/1
Posts: 6,106 |
I read your description, and looked at the pictures probably 5 times, and I don't get it. What exactly did you do, and why?
Mark
2000 Black CSVT
Posts: 7,012 |
Originally posted by tjbugs1: now the brake light will only turn on when I hit the brake or if the lights are on.
this is the only part that i dont get. your third brake light comes on when your lights are on? that isnt a good thing. you dont have reverse lights now either?
Oo (xxx)oO
o xxxxxxxx o
Posts: 345 |
I moved the blinker over to the back up light spot. Sorry my bad!
Posts: 626 |
now, wasnt that easier to say?
Posts: 345 |
The two lights on the back of the car now only do running light/brake light.
Originally posted by m!key: Originally posted by tjbugs1: your third brake light comes on when your lights are on?
No, as you can see in pic two the third light is not on.
Posts: 680 |
Originally posted by GreaseyMonkey: now, wasnt that easier to say?
yes
Black '99 CSVT #741 of 2760
Magnaflow:Knauberized:Mirko:Tinted25%:FogMod:B&G SportSprings:IndigloHvac/Headlight
Posts: 4,270 |
I still have no idea what the hell just happened
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
2000 Green CSVT gone on 2/17/06
2001 Toyota Corolla (SHE RUNS!!!)
1989 Mustang LX 5.0
Posts: 785 |
the tail/brake light are no more used as turn signal, now the backup light are the flasher.
hum what hapenning when you backup ?
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
RU-3530/CTA Intake Pipe
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
SPEC Stage one/Spec Alum. Flywheel
HERE
Posts: 1,939 |
Originally posted by SVT3Rivieres: the tail/brake light are no more used as turn signal, now the backup light are the flasher.
Turn on the hazards and go in spurts!
2000 Silver Frost SVT
# 1637/2150
D.O.B. 01/14/2000
