#1556379 04/23/06 01:22 AM
hello everyone im new here
iwas was wandering if any one has had similar problems
this is about the fourth or fifth tranny thats been replaced in my vehicle it is a 98 svt contour has about 54k on it the first two trannys were synchros and was still under warranty so that was ok then the last one puked the spider gears on the ground and now again gears on the ground
do i not know how to drive?
is there a common mechanical defect in these trannys?
does anyone have one for sale?
any help at all would be greatly appreciated
thanks
#1556380 04/23/06 01:33 AM
F
F
That is way too much transaxle failure, do you race other drivers or run it at the drag strip? The differential is weak under abuse or modified engines, many CEG'ers use the $500 Quaife Limited Slip differential, much stronger.
#1556381 04/23/06 01:57 AM
well i used to race at the track but after the first two trannies went i stopped and only used to drive it on the weekends (was my daily driver) i do get on it but i dont bang through the gears or smoke the tires off at every stop light i dunno maybe my car is cursed
#1556382 04/23/06 02:01 AM
i only have a couple of bolt ons chip exhaust high flow intake just put b&g springs about 12 hrs before this tranny went thank god for aaa i dont mind doing the work cuz i have a lift and stuff but the trannies are getting expensive i found one for 500$ with a 12/12 warranty on it from a bone yard mileage unknown
#1556383 04/23/06 02:33 AM
Instead of repeating the same mistakes (hoping for a different outcome) [the definition of insanity, and stupidity, btw], why don't you invest in a Quaife or Torsen LSD and not worry about it any more.
Have your synchros fixed up, etc through Terry Haines, or the likes for a "bulletproof" tranny that can take pretty much any abuse you could give it.
#1556384 04/23/06 11:25 PM
Welcome bmouyos708 .
#1556385 04/24/06 01:05 AM
I love the title of this post. It reminds me of my 1983 Chevy Impala. It was my first car and I drove that baby into the ground. I once had a parts puking experience with brakes.
Remember when the engine compartment had room to work in it?
#1556386 04/26/06 03:36 AM
Perhaps PM unisys12. He is a resident trans expert at this site. I would stay away from "Bone yard" tranys. Get one or buy one that is Bulletproof if you plan to keep the car.
95 Contour GL. Bought new. BAT Sway Bars/Pioneer CD/Koni Rear Struts/Mobil Fluids. Looking for 15" alloy rims-PM me. 180,500km's so far.
