A k&n filter is easier to remove, with the tight area, because of the "nut" on the bottom of the filter. But even with that I got fed up with oil getting all over the manifold and subframe.
I have no issues now that my oil filter is relocated
what year and model cavalier were you guys working on. i had a 99 z24 and i could change the oil with extreme ease. slide pan under car reach in behind passenger side wheel remove oil drain plug- go to front of engine grab the filter by hand from top and remove with and then reverse of course unbelievably easy
Originally posted by 1slosvt: what year and model cavalier were you guys working on. i had a 99 z24 and i could change the oil with extreme ease. slide pan under car reach in behind passenger side wheel remove oil drain plug- go to front of engine grab the filter by hand from top and remove with and then reverse of course unbelievably easy
Don't even remember, like an 01-03 maybe? Internal filter that's a [censored] to find...
Originally posted by Augi: Hardest I have worked with is a Cavalier, I have seen people quit their jobs over those.
Yes! That thing is just a KILLER to take out. It took me about a week worth of fiddling around in autoshop class. From that time, I hated 1980's Cavaliers, expecially V6 Cavies.
Originally posted by GTO Pete: Ever had to 2-man oil change your Contour with a 3-foot prybar?
I simply used a hammer and prybar. One tough sucker.
Is my car for sale? PM me if you're in South FL.
Originally posted by XKontour98: Haha that's awesome! Go GM!
YES, SIR!!!
General Aviation is Looking good right now...http://www.beapilot.com
Just an FYI for those that havent been around that long the SHMs were the old long tube headers that were made for a short period of time. The covered up all kinds of crap and were probably a ton more trouble than they were worth.
Black 1998.5 CSVTFOR SALE [cleaning house]: SVT rear swaybar. Reasonable offer and its yours!
'91 honda with the D16 (and other engines)have the filter under the intake and on the rear face of the block. This is the worst filter location I have ever seen.
There is no way you can reach the filter form above. Unless you have a lift you must crawl under the car and carefully loosen it with a catch basin under the filter.
I suspect Honda expects everyone to take their car to the dealer for servicing... talk about honda, dealer-friendly design.
