Posts: 604 |
would a 215-50-15 fit on my 205-60-15? I know what the #'s mean, but would a 215 fit a 205 rim? Or should i just stick with 205's?
G/f's black 99se sport 5 speed
2 1/2 test pipe-custom cat back 3 single tip
cai with kn3530
safc optimized tb
8mm plug wires
spec stage 1 clutch
svt front bumper
Posts: 751 |
Originally posted by pimpdcontour: would a 215-50-15 fit on my 205-60-15? I know what the #'s mean, but would a 215 fit a 205 rim? Or should i just stick with 205's?
You don't know what the numbers mean. Yes they'll fit.
Whirling dervish of FFOG.
Posts: 604 |
Originally posted by weargle: Originally posted by pimpdcontour: would a 215-50-15 fit on my 205-60-15? I know what the #'s mean, but would a 215 fit a 205 rim? Or should i just stick with 205's?
ok well 205 is how wide the tire is 60 is side wall and 15 is rim size. i just wanna make sure that 215 will not rub at all, on stock se rims.
cai with kn3530
safc optimized tb
8mm plug wires
spec stage 1 clutch
svt front bumper
Posts: 4,693 |
Jim Johnson
98 SVT
03 Escape Limited
Posts: 4,140 |
Originally posted by pimpdcontour: ok well 205 is how wide the tire is 60 is side wall and 15 is rim size. i just wanna make sure that 215 will not rub at all, on stock se rims.
No, you don't get it. The sidewall number is a is a %. Seriously, spend time time at that site.
Posts: 56 |
yes a 215-50-15 will fit without rubbing, i am running 225-50-15 on stock rim with no rubbing whatsoever, although i would just like to let you know that a 215-50-15 will give you alot more wheel gap then stock, for me the gap isnt too bad, but definately looking at getting lowered to eliminate the gap. hope this helps Jamie
1998 mystique 4 banger atx (wrecked)
1998 mystique V6 MTX --magnaflow muffler-no res, open cone intake(Ractive filter)
Posts: 456 |
01 PORSCHE 996
Merdian/Black
Full Aero
Fabspeed mufflers
Fabspeed CAI
B & M shifter
96 GL MTX Zetec 2.0
White/Blue
Blaupunkdt Houston
K & N Drop in/Koni Kit
18"RageEnduros/Flowmaster 40 Series
Posts: 562 |
'99 Spruce Green SE "Sport" 'Tour, 2.5L MTX...80K and running like it just rolled off the lot.
Tryin' to add an extra .5L ASAP
Posts: 604 |
Originally posted by 98stique: yes a 215-50-15 will fit without rubbing, i am running 225-50-15 on stock rim with no rubbing whatsoever, although i would just like to let you know that a 215-50-15 will give you alot more wheel gap then stock, for me the gap isnt too bad, but definately looking at getting lowered to eliminate the gap. hope this helps Jamie
thank you for this reply. wheel gap don't mean anything to me either. i am droping it in a month or so i think.
cai with kn3530
safc optimized tb
8mm plug wires
spec stage 1 clutch
svt front bumper
Posts: 492 |
That is the size I ran for three years with the BAT kit and it never rubbed.
Jim T.
"Every normal man must be tempted at times to spit upon his hands, hoist the black flag, and begin slitting throats".--H.L. Mencken
Bumper sticker,
OXYMORON #65 - Liberal Thinker
