Posts: 3,570 |
haha ,no kidding, oh well
Posts: 7,117 |
Put some caps on those ST200s or sell them to me.
Posts: 18 |
"I can't even see your rotors" Yes, that is a  problem!
99 Contour SE Sport V6 MTX Frost Silver
Beginning the transformation to a Mondeo ST200 clone. 215/45/17's on Mondeo ST200 wheels
Building a Factory Five Racing Cobra
Posts: 10,015 |
Originally posted by F5R Cobra: "I can't even see your rotors" Yes, that is a problem!
Let me rephrase that - I can't see SH!$, let alone rotors or anything.
i.e. bad picture to use.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,616 |
If I understand this correctly, the brackets for the front will only fit the E1 (smaller) caliper?
War, will I need new (to me) E1 calipers, or calipers and brackets as well to even fit to your adapter?
The reason I ask, is that I have E0 calipers.
TIA
Posts: 10,015 |
Seeing as all Contour knuckles are identical, I DOUBT that the bracket that is going to be used on the E1 SVT calipers would NEED be different to work on E0 SVT calipers. Hence I think the kit will work for ALL SVT's, E0 and E1.
AUSSIE ENDLINKS $70
Posts: 1,616 |
Originally posted by Stazi: Seeing as all Contour knuckles are identical, I DOUBT that the bracket that is going to be used on the E1 SVT calipers would NEED be different to work on E0 SVT calipers. Hence I think the kit will work for ALL SVT's, E0 and E1.
Thanks Stazi!
Posts: 7,117 |
Bump.
I'm ordering brakes next week, so I guess I'm out for the full kit. I might upgrade the rears with this kit later, if the option is available.
Posts: 3,637 |
This upgrade(with baer replacement FSVT rotors) should be sufficient for a Turbo 3L right?
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 7,100 |
I would certainly hope so.. Its what I am running and I have ZERO.. ZERO... ZERO complaints about it.
'99 CSVT - Silver #222/276
