Posts: 2,659 |
Originally posted by bullion: That is still a pretty vague statement....as you said, you had a filter "like" that which means it wasn't a True Flow but it was a different manufacturer of a foam type filter. If this filter was known to fall apart after a short period of time the company surely wouldn't gaurantee it for life...let alone even still be in business. I would check out some of the information on their website...you'll be pretty amazed. On top of acting as a better filter than K & N's and other various surface filters...True Flow will flow just about as good or even better when dirty.
Ummmmmmmm okay. Thats why we have different options. You statement about companies still in business means $@#& because many business have good products that may not work for everyone. In my experience I had a bad time with foam filters. Just cause I had a bat time doesnt mean everyone has a bad time. You like apples and I like oranges its simply as that. I just gave my experience. Thank you very much
99 Contour LX
95 Mustang GT Convertible
97 Z24 Cavalier
Posts: 1,359 |
I'm not saying you didn't have a problem with foam filters. But you cannot conclude that all foam filters are bad because you had a bad experience with one brand. I was just looking for some more solid reasoning/proof that foam filters are inferior to gauze surface filters. After viewing the filter comparison tests and taking into account that the filter has a life time warranty, by deductive reasoning you can conclude that you have not only purchased a filter that will do its job but you have purchased a filter that will last the life time of the car (or they will replace it free of charge).
98' Contour SVT
#607 of 6535
05' Mazda 6s
Audio/Visual enthusiast because it's one of the many things I went through 4 years of hell for
Posts: 5,975 |
The Tornado
states they have tested and using it can:
Save Up To 28% On Fuel!
Increase Horsepower Up To 13 more hp!
Posts: 1,089 |
Originally posted by GTO Pete: The Tornado states they have tested and using it can: Save Up To 28% On Fuel! Increase Horsepower Up To 13 more hp!
my brother got one for his taurus. didnt do anything for the butt dyno and no difference in fuel mileage, up or down.
99 V6SE Sport ATX
Posts: 1,359 |
Not sure why you even posted that link to that worthless device.... If you are trying to imply that companies make false promises every day in their advertising, then you are correct. On the other hand if you are saying that True Flow filters just appear to be a good filter due to marketing schemes, then I disagree. They actually proved that their product does what they claim....that link you posted has yet to be proven effective.
98' Contour SVT
#607 of 6535
05' Mazda 6s
Posts: 9,442 |
Wow, Thanks for the link Pete....Just ordered one!!!!
Posts: 5,975 |
Originally posted by bullion: Not sure why you even posted that link to that worthless device.... If you are trying to imply that companies make false promises every day in their advertising, then you are correct. On the other hand if you are saying that True Flow filters just appear to be a good filter due to marketing schemes, then I disagree. They actually proved that their product does what they claim....that link you posted has yet to be proven effective.
I'm not saying True Flow filters are anything. I'm just saying to take a company's claims with a grain of salt. That's all.
Posts: 439 |
Both of my cars run K&N filters and both have posted Silicon levels well below the universal norms in multiple used engine oil analysis over about 45,000 total miles. For my wifes car the Si levels actually dropped when I switched to a K&N, even though it was a longer oil drain interval than was used previous (meaning that less dirt got past it over an even longer interval of time).
Ohsigmachi '96 GL MTX Zetec
--I don't won't to hurt you, but it's still on my list of things to do.--
View project Slippery Slope
Posts: 1,831 |
Originally posted by ToasterOven: Originally posted by jtour: Is that a foam filter? If so it wont last very long. Go with a K&N filter.
Just my .02
K&N dont do sh!t for keeping dirt out of your engine though
Come on.... I haven't had a problem yet.
A Contour is not just a car, it's an experience
99 T-Red SE Zetec ATX
Born April 16, 1999
98 E0 Silver Frost CSVT
#3175/3565
Born August 21st, 1997
Stored at P.R.T. for the winter
67 Mustang 289 project car
Posts: 6,280 |
That foam filter he's got on his 6s has some kind of frame to it; that black webbing on the outside. I had a foam filter that had virtually no support whatsoever. It gave the same air flow as the stock panel/air box set up. The foam filter came apart and was almost sucked into my engine. I have run the same K&N filter for 3 years. I have serviced it 1 time; I know it's probably due for another. I pulled it off last weekend to mess around with my battery and cables. The intake plenum is dry as a bone (no oil from the filter) but the filter's insides still have some oil. The intake plenum was also completely clean. There wasn't a speck of anything from the MAF to the throttle body. There's nothing wrong with K&N, nor is there anything wrong with a foam filter with some kind of support.
