Posts: 9,065 |
Originally posted by fastcougar: What year/make block? I used a 2002 Escape block and had to use the "skinnier" bolts.
03 Merc sable
Posts: 1,190 |
well grinding wasn't going so well so i took off the head...see arp comes in handy!! sand blasted and painted the mount..looks good....  ...i ground off the dowl pins from the mount cause they would not fit in the block...took the dowel pin out of the block...I got new bolts...M8 1.25 x 100 millimeters two of these and\
M8 1.25 x 70 millimeters two of these also....i put some washers in and the mountbolts on perfectly...now i have to put the head back on...pictures will come later..mount doesn't budge! starting to like power tools...
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese!
diamond pistons for 3.0/forsale
#702 of 2150
Posts: 1,336 |
Originally posted by mapoftazifoshoĆ¢ā??Ā¢: Originally posted by fastcougar: What year/make block? I used a 2002 Escape block and had to use the "skinnier" bolts.
03 Merc sable
That right there might be why ... Taurus/Sable block is definitely different from Escape/Mariner/Tribute block.
Posts: 1,746 |
Originally posted by mapoftazifoshoĆ¢ā??Ā¢: Originally posted by Todd aRRRRRRRRR.: And you used the thicker bolts on the block?
IDK what bolts I used. Little bit a this, little bit a that...
But in all seriousness, I used the stock 2.5L bolts...they worked.
After seeing that...I'm afraid to ride in your car...
Anyways...Lets get this all straightened out.
The Contour mount/bolts(?) will work on which blocks? The Cougar mount/bolts(?) are needed for which blocks?
2000 Contour SVT
SF - #542 of 2150
Posts: 9,065 |
Well all those bolts are from the 3L that I didn't need. I don't need 2 sets of header bolts and studs. I also didn't need all the timing cover bolts, and then the valve cover bolts.
As far as the taurus motor, I think Todd used a taurus block.
Posts: 1,746 |
Originally posted by mapoftazifoshoĆ¢ā??Ā¢: Well all those bolts are from the 3L that I didn't need. I don't need 2 sets of header bolts and studs. I also didn't need all the timing cover bolts, and then the valve cover bolts.
psst...I was only kiddin...hehe. Call it poor sportsmanship, because you beat me on finishing the 3L. hehe
2000 Contour SVT
SF - #542 of 2150
Posts: 1,190 |
Originally posted by posthuman63t: Originally posted by mapoftazifoshoĆ¢ā??Ā¢: Originally posted by Todd aRRRRRRRRR.: And you used the thicker bolts on the block?
take the spark plugs out of the picture and the bolts with the rubber washer which are for the valve covers and there is really not much left...looks like you have some front cover bolts...couple lower intake bolts...tranny bolt
#702 of 2150
Posts: 5,810 |
Originally posted by posthuman63t: Originally posted by Todd aRRRRRRRRR.: Way to read the fuggin stickies.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=3L&Number=740593&page=0&view=collapsed&sb=5&o=2&fpart=1
2nd up from bottom. And also in the top sticky. You need 2 long bolts and 2 short bolts. Contour mount will not bolt to the 3L block. Different bolt size. Cougar mount is $32 from Jenkins.
OMG I overlooked something....?!?! That sucks...so technically ALL 3L's in tour Have to have the 01+ Cougar mount...
No, you can just drill out the holes in the motor mount to fit the larger holes on the older blocks and on the newer blocks the bolt holes are the same as the 99+ bolts.
See My Mods
Posts: 1,190 |
wrong...my 2001 block has smaller bolt holes in the block than the 2.5...its not the size of the holes in the mount but the size of the bolt that fits in the block. the dowel pins pressed in the mount were too big to fit in the 3 liter block also.
#702 of 2150
Posts: 5,810 |
okay, you had the earlier mount/bolt style, no biggie. I mentioned the later style. In your case you just use the escape/contour mount with the smaller bolts. They were identical on my engines. 99SVT->'01ESC
See My Mods
