i got a 96 contour, GL, v-6 engine. they have two fans.. the one for the HOT engine comes on a few seconds after the motor is started.... no problem with this and the engine temp. gauge stays at O on Normal Scale.... But when i put the A/C on the A/C fan for the radiator does not come on. i think this fan should be on all the time when you click the a/c on? the car will heat up and the temp. guage will keep going all the way over to the L and then some in NORMAL. i then shut off the A/C and the temp will drop back down to N or O on the guage. i replaced the High Speed Cooling Fan relay, in the elect. box under the hood thinking this might be the problem. it did not help. any guesses????? I hate to tear out the Fan motor to replace it.
the Haynes book seems to make this alot of work.. the old CD that i had gave more info and I lost it to the flood water of the Hurricane. Any help will be appreciated...
thanks..
djbird@sprynet.com
