Posts: 17 |
I'd like to wake up my Zetec and am thinking about starting with the intake. I've heard that a K&N filter will make a difference, but I'm wondering if something like a KKM Tru-Rev system is that much better than a K&N to justify the extra expense. I'm just looking to optimize the stock settings, not build a racer.
Posts: 1,118 |
just a filter isnt gonna do a whole lot. granted if its an open end cone, it is going to be a little more responsive, but go the extra mile and take a look at sleeperz's intake setup in the stickies im running it right now, and i can tell you that it deffinatly woke up my zetec!
kevin m
98 T-red mystique gs
zetec ATX
| my ride |
Posts: 1,687 |
I just so happen to have what you request! Hey Mods sticky me so I don't have to keep telling kids how to do this one! Thanx!
J.T.'s MERC-0-MATIC SHORT RAM HYBRID INTAKE
Step 1! Go down to your local Autozone and buy: -3" silicone connector w/clamps
-3" inlet paper-media cylindrical air filter. Part# should be PA**** for a Purolator.
-3M or Scotch brand packing tape. The kind with the fibers inside.
-(optional) aftermarket breather filter.
-Flat-head screwdriver, 1/4 inch driver ratchet with 9 or 10mm socket for battery ground nut.
Step2! Installation!
A. Open up hood and disconnect battery ground by loosening nut and removing black (negative) cable from battery.
B.unclip top of stock airbox from bottom.
C. GENTLY unclip and remove MAF from upper portion of stock airbox. set airbox aside and disconnect electrical connector from MAF. KEEP TRACK OF THE CLIP!!!!
D. Unloop rubber retaining band from far driver-side of the lower airbox. Hold onto this band in case you want to return to stock. Carefully pull back rubber connector from lower airbox that leads to the driver-side fender. Remove stock breather filter assembly from airbox(it's in the corner and attached to a tube. A hose leading from the valve cover is on the outside) If you twist it, it will come out without too much trouble, just keep trying. You can either keep the stocker or install the aftermarket breather here. Then GENTLY pull lower airbox out of retainers. It may take a bit of effort, but don't get rough with it.
E.(PRE98 ONLY, Post98 skip this step!) remove tubing and MAF from the intake resonator (the plastic thing above your ignition coil). Use packing tape to cover hole in intake tubing across from IAT sensor. Be careful not to pull the IAT wiring out. Better yet, just remove the connector beforehand, however be SURE you reconnect it.
F. Reconnect tubing to resonator but not MAF yet. Remove rubber ring from MAF if you have a metallic one, not so sure about the Post 98s. Slip 3" silicone connector over MAF. IT may take some effort, but it will fit. Tighten MAF side hose clamp.
G. Insert air filter inlet into 3"connector with MAF. I know this sounds retarded, but make sure you put the clamp on the connector before you put the filter in the connector. It saves time and frustration;). Tighten filter-side clamp.
H. insert MAF into intake plenum/resonator tubing and tighten clamp. Make the filter fit how you want it to in your engine bay, as many people don't have the same size batteries, there is no specific setup here, so just make it fit.
I. Reconnect MAF and IAT sensor connectors. Remember to re-clip the MAF connector.
J. Reconnect battery ground and start her up. Drive around for a while and let the ECU relearn with the new air intake. After the computer adjusts, you should notice markedly improved throttle response and slightly faster 1/4 mile times, along with a certain intake howl with certain brands of filters. The FRAM made the most distinct howl, but the Purolator provided the best ETs. I went from an 18.7 to an 18.4 under good conditions both times. I'm not making an absolute guarantee, but that's what you might expect. IF you have any questions PM me. I'll try and get GS474 to post a pic of the setup. I did his for him. Alas my Merc is no longer ...
Step 3! Enjoy!!
J.T.
2002 Chevrolet Silverado 294ci V8. Custom CAI, headers on the way...
1997 Mercury Mystique Zetec ATX
Deceased February 2006
Posts: 2,542 |
Posts: 979 |
Just wondering would duck tape work? I don't have the packing tape. I need that hole pluged, that thing sticking out over the ignition coil is useless.
My ride(Cardomain link) :
'95 Contour 16V Zetec DOHC, Teal , ATX
Born on Sep. 4, 1995
86+ miles
*LEDs mods are on their way!*
Posts: 498 |
just go the junkyard and get a post 98 tube w/ iat on it, it removes the one intake resonator.
96' ATX Zetec- stock
96' ATX Zetec- Modded
Kenwood KDC-319
5.75"-2 MTX 12's
Roady XT
Custom door panels
Mystique Cluster/oil pressure
Getting repainted(in primer)
Pre98 Lip
SE skirts
Mystique front lip
dingless
badgeless
Posts: 1,687 |
Yeah. Duct tape will work. Just don't use anything too flammable. It looks better if you install a Post 98 intake tube though. I used tape.
J.T.
Posts: 5,143 |
if you can find one... get a used CTA motorsports air intake, every time I get on the gas pedal and hear that thing wake up I get a little grin on my face. It has never let me down and never ceases to amaize me... How a little Air intake for a I4 can be louder then my exhaust.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 979 |
Originally posted by AliasJerkââ??¢: if you can find one... get a used CTA motorsports air intake, every time I get on the gas pedal and hear that thing wake up I get a little grin on my face. It has never let me down and never ceases to amaize me... How a little Air intake for a I4 can be louder then my exhaust.
If I get luck enough and find a CTA for a resonable price, I'd get it, the only problem would be to make a IAT hole for me Contour.
Right now, I have stick w/ stock cause I just got a K&N filter.
86+ miles
Posts: 5,143 |
Originally posted by Kerry2Kool4U: Originally posted by AliasJerkââ??¢: if you can find one... get a used CTA motorsports air intake, every time I get on the gas pedal and hear that thing wake up I get a little grin on my face. It has never let me down and never ceases to amaize me... How a little Air intake for a I4 can be louder then my exhaust.
ummm the CTA intake is designed for the contour... All of mine bolted right up.
TEIN H.Tech Springs
