Posts: 31 |
I have just completed a full 3.0 swap into my 1999 CSVT. It now has a 2001 3.0 with all the stock injectors, throttle and MAF items on it. I am working on a dummy set up for the 2.5 IMRC, it is currently not hooked up, giving me a CEL. I had some vacuum issues at start up that are now resolved. It starts and idles fine, and flat hauls when you get on it.
It has a slight hesitation from off the line, and some surging at low throttle. This causes some bucking of the car, kind of embarassing. I have only driven it 2 or 3 miles, everything seems to be good under the hood, no more leaking lines.
Any thoughts on what could be going on? I am not planning to chip the car, I have spent enough on it, I want to drive and enjoy.
Thoughts?
1999 Green Contour SVT 3.0
1999 Black Corvette 6 Speed (FOR SALE)
2000 GTP Pace Car
1993 Lumina Z-34 (SOLD!!!!)
2000 Blazer ZR/2 (FOR SALE)
1993 Eagle Talon (my baby)
1970 Camaro, since 1974
Yeah, I need more cars!
Posts: 9,065 |
Originally posted by green1999csvt: I have just completed a full 3.0 swap into my 1999 CSVT. It now has a 2001 3.0 with all the stock injectors, throttle and MAF items on it. I am working on a dummy set up for the 2.5 IMRC, it is currently not hooked up, giving me a CEL. I had some vacuum issues at start up that are now resolved. It starts and idles fine, and flat hauls when you get on it.
Thoughts?
What kinda of intake manifolds are you running and when u say stock inkjectors do u mean green top 19# injectors or what!?
Posts: 21,197 |
If you're running 24lbers no wonder. It' most likely pooling up fuel. You need a tune ASAP.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 1,943 |
the 3.0L
oval port 3.0L '98 midnight blue se
Posts: 31 |
The injectors came with the 2001 Taurus engine. I thnk they are tan color. I did not reuse the SVT injectors, but could switch to them. As I recall, the 3.0 looked just like the 2.5. I can look more tonite.
What is the 3.0L emblem from on your car?
Thanks
2000 GTP Pace Car
Posts: 1,943 |
well since the post from adc about the injector sizing, id flow them before any tuning... my beige ones in my 2001 taurus motor flowed 19# at 45 psi whereas my grey ones on my 2000 taurus motor flowed 24# at 45psi. with the ford rating at 40 psi those injectors are 17# and 22# respectively.
the 3.0L
Posts: 31 |
My understanding was they were the 19# injectors and that with the 3.0 MAF they would work with my SVT PCM. I just looked at them and they are the beige ones.
2000 GTP Pace Car
Posts: 21,197 |
Use the Contour MAF! It's matched with the PCM and injectors.
-'96 SE MTX 3L
Posts: 1,746 |
Originally posted by Yummy Mummy: Use the Contour MAF! It's matched with the PCM and injectors.
x2
2000 Contour SVT
SF - #542 of 2150
Posts: 31 |
I have swapped them back and forth, doesn't seem to matter. Looking into a tune to solve low speed throttle response issues. It won't tune itself.
I will try the 2.5 MAF today, just to leave no stone unturned.
2000 GTP Pace Car
