Posts: 1,165 |
I live in Detroit, I couldn't give a **** how good my car is in the "twisties."
"I could use a hundred people who don't know there is such a word as impossible."
~Henry Ford
Posts: 1,978 |
Wow, Thats a TH prepped trans? what happend to it.... not knocking anyone just curious
Alex
'99 SVT Contour
Posts: 1,165 |
I should say this, even tho it doesn't matter due to the nature of the failure. But it was a budget rebuild, no LSD, that is a stocker diff you see in the pics. Still looks pretty good tho.
~Henry Ford
Posts: 2,033 |
Originally posted by 99SVT: I should say this, even tho it doesn't matter due to the nature of the failure. But it was a budget rebuild, no LSD, that is a stocker diff you see in the pics. Still looks pretty good tho.
Well...stock diff...key words right there.
But otherwise, how the hell do you drive??
Posts: 1,165 |
Originally posted by GetLucky151�©: Originally posted by 99SVT: I should say this, even tho it doesn't matter due to the nature of the failure. But it was a budget rebuild, no LSD, that is a stocker diff you see in the pics. Still looks pretty good tho.
It's my understanding...and I'm no expert. But I have seen blown diffs, and the teeth on this one still look great. It is the bearings that failed. Faulty part or not pressed on properly or something else.
~Henry Ford
Posts: 9,065 |
Looks like deer poop in his tranny! Maybe this weekend I can come down and offer my expertise.
Posts: 1,165 |
Deer poop > Ford Honey
C'mon down I'm sure I'll be puttin it back together all weekend. Thanks for the clutch alignment tool btw.
~Henry Ford
Posts: 7,392 |
Originally posted by 99SVT: It is the bearings that failed. Faulty part or not pressed on properly or something else.
def a bearing crapping the bed, followed by subsequent carnage. that sucks! but it does happen.
.....______
___|______\_____
|/-\_________/-\_|
.\_/...............\_/
Posts: 1,336 |
I'll wait for Terry to chime in, but it looks like the bearing damage caused other issues ... now, what caused the bearing damage? #1 cause of bearing damage in engine/transmission/turbo/anything that uses a bearing is lack of lubrication ... now what caused that? see where I'm going with this? Good luck!
Posts: 1,943 |
you obviously didnt have your tierods and balljoints off...
the 3.0L
oval port 3.0L '98 midnight blue se
