Posts: 1,593 |
The Auto zone's I have called (I gave them the Motorcraft SWE-5020 part number to cross reference) are calling the "Clutch pedal position switch" the "Neutral Safety Switch." Does that sound right?
MUST SELL - ECM computer new for a 98 V6 mtx + pats
Now trolling in a Red Nissan 4 x 4
Posts: 1,593 |
All right I picked up a Camshaft position sensor which I will install tonight. I also ordered a Clutch position switch and a crankshaft sensor...
Anything else I ought to check?
Posts: 5,345 |
Originally posted by mean'tour: All right I picked up a Camshaft position sensor which I will install tonight. I also ordered a Clutch position switch and a crankshaft sensor...
How about wiring? Battery to alternator, battery to starter, battery to ground as well as wire which runs between the battery and air filter housing.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=47010&fpart=1&PHPSESSID=
1996 V6 ATX 96K miles
Posts: 1,456 |
I have had a bad battery not take a jump start. A good but depleted battery should jump start, if all wiring is in order.
Posts: 512 |
Would a starter motor be good on Friday and bad on Saturday? How would I test it?
It is not likely that it would happen while you were fixing something else, but it is defiently possible. That is exactly what happen to me when I replaced the fuel pump on my Escort. My starter went which obviously was completely unrelated to my replacing the fuel pump.
For Sale - 96 Tour Sport 2.5L MTX with SVT Exhaust, pre 98 trunklid with newer Contour Sport spoiler instead of lip spoiler, newer Contour sport rims. Newer paint job. Brand new floor mats. Rust Free! PM me for details and pics.
Posts: 5,345 |
A better description of where the Clutch Pedal Position Switch is . Originally posted by 1SWT4DR: ...If you get under the dash and look up and behind the clutch, you will see a switch with a couple of wires attached to it. (Make sure you are looking at the right switch... as there are 2 switch on the clutch... it is the one that is activated when the clutch is pressed all the way to the floor.....
