Wait at least 10 minutes rather than 1 minute to be safe. The airbag backup supply is the capacitor which stores the energy. The waiting takes care of this issue. I'm not sure if the capacitor is in the air bag module.
From 1996 Ford CD manual. Clockspring a.k.a. air bag sliding contact.
Module, Driver Side Air Bag
Removal
Note:
If the driver side air bag module did not deploy in a collision, it may not have been needed. Complete all diagnostics before replacing the driver side air bag module.
1. WARNING: THE ELECTRICAL CIRCUIT NECESSARY FOR SYSTEM DEPLOYMENT IS POWERED DIRECTLY FROM THE BATTERY. TO AVOID ACCIDENTAL DEPLOYMENT AND POSSIBLE PERSONAL INJURY, THE POSITIVE BATTERY CABLE MUST BE DISCONNECTED PRIOR TO SERVICING OR REPLACING ANY SYSTEM COMPONENTS.
Disconnect battery ground cable.
2. Disconnect positive battery cable and wait one minute for back-up power supply energy to be depleted.
3. Remove five retaining screws and upper and lower steering column shroud from steering column tube.
4. Rotate steering wheel to remove air bag retaining bolts (one on either side) from steering column side of steering wheel.
5. Carefully remove driver side air bag module from steering wheel.
6. WARNING: PLACE AIR BAG MODULE ON BENCH WITH TRIM COVER FACING UP TO AVOID ACCIDENTAL DEPLOYMENT AND PERSONAL INJURY.
Disconnect the air bag electrical connector from air bag sliding contact connector. Remove driver side air bag module.
Installation
1. Note: Fill out and return air bag traceability postcard for new air bag with VIN numbers and note diagnostic trouble code.
Connect air bag electrical connector to air bag sliding contact connector.
2. Position driver side air bag module to steering wheel and secure with two retaining bolts. Tighten to 4-5 N-m (35-45 lb-in).
3. Reconnect positive battery cable.
4. Reconnect battery ground cable.
5. Prove out air bag system.
Sliding Contact Air Bag
Removal and Installation
1. Make sure that vehicle's front wheels are in the straight-ahead position.
2. Remove steering wheel and driver side air bag module as outlined.
3. Remove steering column shrouds as outlined.
4. Disconnect air bag sliding contact wiring harness.
5. Apply tape across air bag sliding contact assembly stator and rotor to prevent accidental rotation.
6. Release three air bag sliding contact locking tabs and lift air bag sliding contact from steering column.
7. To install, reverse Removal procedure.
