#1544302 04/07/06 02:11 PM
MattB Offline OP
Is there any tricks or tips to clean Oil from my driveway? It was there before we moved in, but my wifes car was leaking too. Everytime it rans the oil tends to run down the driveway, anyway to get rid of it?
Thanks
Matt
'97 Pumice Zetec Sport- 'At least its not a geo!'
If it is reather fresh, laundry detergent powder and a stiff bristled broom (like a wide floor broom, etc) to scrub until the suds are black will remove most of it. Don't add ANY WATER until you are DONE and HAPPY with the final outcome.
if its OLD.. pressure spraying would be the way to go, I would think.
grease lighting should take it off then just hit it with a hose.
G/f's black 99se sport 5 speed 2 1/2 test pipe-custom cat back 3 single tip cai with kn3530 safc optimized tb 8mm plug wires spec stage 1 clutch svt front bumper
E
E
My driveway is on a slight hill so it's pretty easy to rinse it off, but I've had good luck with Simple Green on fresh oil, brake fluid and gas. (I guess I should stop spilling...)
MUST SELL - ECM computer new for a 98 V6 mtx + pats Now trolling in a Red Nissan 4 x 4
i use that grease lighting to take off tar from the car then hit it with the purple clay bar. that stuff works for every thing. i use it on my rims aswell for brake dust.
