Posts: 9,872 |
guess it'll be the coil pack now..think that might fix my idle problem?
Posts: 4,970 |
If you have a bad coil pack, then it could easily cause an idle problem.
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 9,872 |
Originally posted by TC'd Swazo: If you have a bad coil pack, then it could easily cause an idle problem.
well lets hope that it is cause after this, im outa ideas
Posts: 129 |
well you can just get a coil pack from autozone to try and if that doesn't fix it, you can just return it  i had the same problem on the se before and thought it was my coil pack but it ended up being my wires. had bosch wires on there for about a month that fixed the misfiring but then it came back and actually started to melt one of the boots on the wire. ended up getting some autolite wires and those ran pretty well.
Posts: 129 |
oh yeah and i changed the fuel pump filter too. that helped smooth everything out a LOT. idle and acceleration were as smooth as a baby's bottom.
Posts: 9,872 |
Originally posted by ronin45: oh yeah and i changed the fuel pump filter too. that helped smooth everything out a LOT. idle and acceleration were as smooth as a baby's bottom.
well my fuel filter is brand new (2 months old) fuel pump is working fine with the psi being at 43..my wires are brand new magnecors..plugs are brand new with no signs on carbon after 2 months of use..so i hope like hell its my coil pack..
Posts: 8,445 |
so get a coil pack..and come to UCONN
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
Posts: 9,872 |
Originally posted by Count Chockula: so get a coil pack..and come to UCONN
wont be here till tuesday! jesus elky i offered to drive ur svt to uconn..with my projectors..but oh well
Posts: 802 |
Originally posted by Goonz SVT: Originally posted by outkast: Most members hate Bosch+4 plugs.I,ve replaced both of my duratecs with bosch plugs and the problem went away!
autolites never gave anyone trouble either..
Now why would I change from auotlites to bosch? It could be the mixed fuels we use in Maryland
New Pics of OUTKAST 1!Sept2006
CEG road warrior
CEG road warrior
Posts: 17,248 |
PUT THE STOCK REPLACEMENTS IN!  Get the Magnacores out!  Even Magnacore wires suck for the Evo.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
