Page 1 of 4 1 2 3 4
Kept myself busy by changing a couple of parts on my car over the weekend..
And so it begins with disassembly:
Where did the rear suspension go?
Remove the subframe to get the lower control arm bolts out on the drivers side?? I don't think so - time for death by Sawzall:
Why not do the intake while I am at it..
Tons of carbon built up over the years:
Clean and prep for powdercoat:
Junkyard special Focus brake upgrade:
After some bead blasting
Might as well do the bearings at the same time:
Time to fab up and weld some brackets for sway bar:
Swap the struts/springs (nice to have a spring compressor handy):
I knew these ratchets were good for something:
Finally reassembly time - The parts..
Koni Sport Kit:
Slight difference in height:
Roush Bar and custom end links (to those without a welder - I would not advise the tall energy suspension mounts):
Powdercoated brakes and knuckles:
New bearings:
Everything back on the car:
Powdercoated and turned junkyard rotors look good as new (aside from the overnight rust):
Stainless Goodridge lines:
Caliper close-up and speed bleeders:
The rear - still working on machining up brackets to use the front rotors on the rear this week hence the rusty rotor and pads:
Finish up the intake (After 6 cans of STP TB Cleaner)
And several cases of beer and 2 days later - the car all done (now time to wax after the winter season..):
I'll have to get some better shots of the complete car in the next couple of days.
Now onto next project (some assembly required):
Deffinition of hawtness------>your car..............
Now I just need to do the same to my car.
Keith P. Killed in action-4/27/06 '99 CSVT #2369/2760-7/28/99 New Recruit- 1998 EO CSVT # soon to come Black 106,xxx
Damn, now I wish I had cleaned my car up more...but limited $ = limited mods.
Ditto
Agree!!
your car is hot... i cant wait to get those wheels for my t-red
Another superb MI car. Get that thing to SZ in May!
so how much are you charging to do this again? i'm only a little hop skip and a jump away, wanna take me under your wing this summer
Black '99 CSVT #741 of 2760 Magnaflow:Knauberized:Mirko:Tinted25%:FogMod:B&G SportSprings:IndigloHvac/Headlight
Nice job Craig. I see me new SKF bearing sitting happy in there.
Stazi - Thanks a million for helping me out by keeping your "parts warehouse" open all of those late evenings!! Figured you'd like that pic .
W
Back In Black
Back In Black
W
Wait... my car is usually the clean one, now I gotta go wash it again! It looked great when i was leaving today, now you just gotta keep it clean! haha
1999 Black-N-Tan SVT Contour #291 Check out CD338.com:: The Premier Ford Fusion Site!
Page 1 of 4 1 2 3 4
