Here's some tidbits that I pulled off the TeamZX2 forum...
Right now, we are looking at a water to air intercooled system using a Lysholm Twin Screw supercharger running 8 psi.
We are planning on using a dual Laminova water to air intercooler cores, which allows for the integration of the cores into an engine specific cast aluminum manifold, decreases any pressure drops, and increased response due to short flow length in the system (100 mm or ~ 4 inches from supercharger to intake ports)
-OPCON AUTOROTOR 2076 Twin Screw Supercharger <--now a 2087
-SEAM Pulley (8PSI)
-Serpentine Belt
-SEAM Cast Aluminum Intercooler Module
-SEAM Billet Aluminum ICM end caps
-SEAM OA2076 Mount Plate
-SSE ZX2 Intake Runners
-SEAM Coolant Reservoir (1 or 2 liter still under discussion)
-Dual Laminova water to air intercooler cores
-BOSCH High Capacity Fuel Injectors
-SSE Reflash (Currently looking at various ways to manage fuel)
-MOCAL front mount heat exchanger
BOSCH 4GPM Coolant Pump
-SSE Cold Air Intake
-K&N Filter
-Misc Hoses for coolant transfer
-Misc Brackets
-Misc Clamps
-1 Year Unlimited Mileage Warranty
-Installation Manual
OPCON AUTOROTOR 2087 Twin Screw Superchargers and the Laminova 45MM diameter water to air intercooler cores
Instead of the cast aluminum design the manifold will now be made from composites and aluminum...
I found this info searching the web)
Opcon Autorotor OA 2087
Displacement: 0.87 Litres / 53 Cubic inches / revolution
Max Air Flow: 215 L/s; 460 CFM
Dimensions: Length: 245mm; Width: 157mm; Height: 103mm
Suited for: 275 BHP / 205 kW Engines
The supercharger size is perfect! At 2bar with a 100%VE, our Zetec draws 457CFM at 6500rpms. That'd work out to 315 crank horsepower.
