Page 2 of 3 1 2 3
#1540689 04/13/06 07:04 PM
Originally posted by Christian:
Ball joints & tie-rods are okay from visual inspection....
You might want to put it on a jack stand (or lift) and do the 3 and 9 o'clock test. In addition, if it is safe enough, go directly under and pull/push at the ball joint. You can tell if it is loose. Compare with the other side (unless of course, both are bad).
#1540690 04/13/06 07:28 PM
Has anyone mentioned something as easy as the front caliper clips. If one is off it will pull to that side.
#1540691 04/17/06 06:57 PM
Finally found the problem !
Turns out to be drivers side LCA bushing. Apparently it was missed first time as it was tested on a hoist, and so I've been informed by someone who knows, it didn't show because the force from the supsension!
Now hopefully I can get it changed with help from the LCA Tips thread which links to GrooveNerd's thread on the topic.
Thanks to all!
1998.5 T-Red on Midnight Blue SVT Build Number 5320 of 6535
#1540692 04/18/06 07:30 PM
Replaced LCA and it did not change anything.
So far all the above has been done.
Applying handbrake does not make car pull, so it's not the rears, although this doesn't rule out the hydraulics.
Front caliper pins okay ... basically everything so far has passed it's inspection!
We're running out of ideas fast, I wondered about subframe bushing.
#1540693 04/18/06 07:36 PM
I know it may sound dumb but check the tires.. because it may be how the tire is wearing down. i use to work in a stealership and there was a car that kept pulling and the tire was wore really weird.
#1540694 04/18/06 08:03 PM
Tires are just installed and balanced, the problem was the same with the old snows on as it is with these new Michelins. Tire wear is normal.
#1540695 04/19/06 01:52 PM
Sounds like toe-out. Have you had the car aligned? Are you sure there's no play in the steering/suspension?
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
#1540696 04/19/06 02:36 PM
I have these symptoms as well and have had little luck finding the actual problem. We have found many other things but not THE problem.
I am curious to know what are symptoms of steering rack failure / wear?
#1540697 04/19/06 02:40 PM
Originally posted by stickyjazz:
...I am curious to know what are symptoms of steering rack failure / wear?
Loud moan when turning (especially at low speeds).
#1540698 04/19/06 05:33 PM
Car has been aligned twice, maybe three times now with LCA change ... still the same!
Page 2 of 3 1 2 3
