Posts: 316 |
I'd like to pick up injectors larger than 42# green top Lightning injectors for a 2002 Escape block. Does anyone know which injectors to get, and where to get them?
Thanks.
Posts: 1,746 |
I hope you have a turbo...
Might have better luck having a mod move this to the forced induction area if you DO have a turbo. Other wise you seriously need help if you want to put such huge injectors on a N/A app.
2000 Contour SVT
SF - #542 of 2150
Posts: 3,732 |
he has a twin turbo 3L duratec......in a noble
Russell
Oval Port 3L Nearly Done
Posts: 1,746 |
ooo0000 perdy. I still thin kthe FI guys will know better.
2000 Contour SVT
SF - #542 of 2150
Posts: 5,810 |
Originally posted by gotapex: I'd like to pick up injectors larger than 42# green top Lightning injectors for a 2002 Escape block. Does anyone know which injectors to get, and where to get them?
Thanks.
Ebay.
There are some Siemens injectors that I saw that would fit, and some Delphi injectors. I think I saw 66# Delphi injectors that should work on ebay.
See My Mods
Posts: 316 |
Thanks guys. Any suggestions from http://www.fiveomotorsport.com/ as to which one to get?
Posts: 10,015 |
Go on eBay and look for a set of Terminator injectors (S/C'd Cobra) they're 38# (rated the same as 42's at a higher pressure). There are a lot of Cobra owners selling them off as they bump up the HP and exceed the flow-rate of the stock injectors. I bought a sset for my 3L build-up with bigger turbo.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 611 |
I think he wants injectors larger than 42's. If so pick up a set of 60lb injectors. A guy in my office just picked up a set for his Supercharged 98 Cobra because the 42's were maxed out.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
Posts: 316 |
Thanks for the help guys, I appreciate it. I just placed an order for six 750cc/min injectors from RC Engineering. That should give me just a hair more headroom than the stock setup if we hit our targets.
