Posts: 1,359 |
I got my SVT out of storage yesterday with the intent to install some of the parts that have been sitting in my basement for a while now. I was planning on installing my catless sho shop y-pipe today, but I am not quite sure how to get the stock catalytic converter off. It appears that the cat and resonator are attached to each other via a two bolt flange, but when I looked closer I don't think they are bolts. They are more like rivots (i.e. bolts with flat tops). Any ideas if this can be easily removed?
98' Contour SVT
#607 of 6535
05' Mazda 6s
Audio/Visual enthusiast because it's one of the many things I went through 4 years of hell for
Posts: 3,637 |
they are bolts, your just have to take off the nut, they are pressure bolts (aka no need for the standard bolt end)
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 1,359 |
I looked at it closer to make sure of what you said. I was only looking at the one side of the flange. Well, it appears that one of the nut rusted off on one side (unless only one side of the flange is suppose to have a nut). So as it is right now, one of the two bolts has a nut and the second does not. I am guessing that if I remove the one nut that is still on there i can maybe punch the remainings of the other bult out with something....what do you think? Also, what are the specs of those exhaust bolts since I am going to have to get some replacements (or can I just go to Ford and get them)?
98' Contour SVT
#607 of 6535
05' Mazda 6s
Posts: 3,637 |
Yea, just remove the other nut (use some PB plaster or liquid wrench anti-rust) after thats done you can just remove the stock main cat and everything should be good (are you installing a test pipe in place of the main cat?)
The bolts you need are: 3/8" x 1 1/2" stainless steel bolts and locking nuts that can be found at any hardware store. Just use a washer on either end.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 1,359 |
Ok good. As for the test pipe....I bought this part used from another CEG'R a while back so it is what it is but yes, it has the bypass pipe (aka tubing in place of the cat).
98' Contour SVT
#607 of 6535
05' Mazda 6s
Posts: 3,637 |
everything should bolt up properly then, tell us how its sounds after!
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 1,359 |
I picked up the bolts you told me to get....kind of crappy that the total came to $5 for just two bolts, some washers and locking nuts but oh well Is there any reason why you told me to get 3/8" bolts? They will definitely work to connect the exhaust as long as I use the washers...I guess I was wondering why you didn't tell me to get a larger size bolt. Either way, this should work...
98' Contour SVT
#607 of 6535
05' Mazda 6s
Posts: 3,637 |
its cheaper than what ford would have sold you.
i used 3/8" for every exhaust bolt on my car, its what i measure to work the best, i guess you coulda gone 5/8" if you wanted but it might have been to large and i didnt want to drag my y-pipe into the store to test out bolt sizes.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 1,359 |
I might install the pipe tonight if I have time....i'll let you know how it sounds
98' Contour SVT
#607 of 6535
05' Mazda 6s
Posts: 140 |
I'd love to hear the CSVT completely CATless, can you get a audio sample of it with the test pipe?
1999 Black/Tan CSVT
#2658 of 2760
201,000+km
- K&N, Magnecor race wires, Optima red top, BAT Euro Kit, KVR CF pads, PIAA Plasma Ion bulbs.
1989 Yamaha FZR600 - 40,000+km
- K&N Pods, Stage 3 Jets, V&H 4-1 exhaust
