Page 2 of 3 1 2 3
#1540251 04/04/06 04:10 AM
lubas79 Offline OP
one more
If i put 21lbs injectors and buy arizona chip have a y-pipe resonator k&N filter
do you think it will change anything
or I should just chill out buy a chip and let it go
1999 CSVT
#1540252 04/04/06 04:56 AM
You don't really NEED 21lb injectors, but you can still use em (make sure your car is tuned for them). Don't get what you mean by y-pipe resonator...You can optimize your y-pipe, that'll help. A K&N I wouldn't say necessarily does much, give your car a better sound, maybe...MAYBE a 1 HP. lol. uhm, and I would suggest a local place to get your car dyno-tuned over a mail order chip. Dyno-tune will be perfect for your app, but a mail order chip wont be, although if you can't afford the dyno time, ADC would be the way to go.
With all this done, you should expect some decent gains...nothing that is going to throw ya back in the seat and make a HUGE Noticable dif tho...
2000 Contour SVT SF - #542 of 2150
#1540253 04/04/06 06:07 AM
#1540254 04/05/06 02:40 AM
lubas79 Offline OP
nice so anybody who has dyno can tune my car, I am in Ny, mechanics are here to f**k anybody over any help
1999 CSVT
#1540255 04/05/06 02:22 PM
not unless they have the correct software. (i.e SCT)
#1540256 04/05/06 02:30 PM
Im sure there is an SCT authorized tuner in New York somewhere
#1540257 04/05/06 02:32 PM
http://www.sctflash.com/
Enter your zip code and it will tell you the closest place to have your ECU programmed.
2001 Lincoln LS8 1994 Lexus GS300
#1540258 04/06/06 01:26 AM
lubas79 Offline OP
great
now what if I get the SCT flash device by buying it will this be sufficient enough, \
thanks
1999 CSVT
#1540259 04/06/06 02:13 AM
Sufficient enough for what? Tuning the ECU will only maximize the potential that you already have.
#1540260 04/06/06 02:21 AM
lubas79 Offline OP
ok so I sould still go to the dyno shop and what they will do
1999 CSVT
Page 2 of 3 1 2 3
