To continue thinking out loud, here's a chart but with the MAF.ia values and some that I've calculated...
Code:
Vin to Vout Adjustment Equivalent PR Equivalent Boost
5.0 V to 5V None 1.0 None
5.5V to 5V 24% or mult by 0.76 1.316 4.64psi
6.0V to 5V 41% or mult by 0.59 1.695 10.22psi
6.5V to 5V 53% or mult by 0.47 2.128 16.58psi
7.0V to 5V 62% or mult by 0.38 2.632 23.98psi
7.5V to 5V 70% or mult by 0.30 3.333 34.30psi
Sure as heck is enough headroom for any turbo setup. The only limiting factor would be the diameter of the MAF itself.
By using an op-amp you could have any multiplier that you want. Not the coarse 5 settings that the Mafia gives you. You could dial it in to the exact HP that you are making giving you the best resolution.
BP
